LS crank shaft and rods in a GSR - Is it worth it?
Old Aug 29, 2007 | 01:48 PM
GSR in progress 96's Avatar
* B A N N E D *
Default LS crank shaft and rods in a GSR - Is it worth it?
I have been thinking about putting LS crankshaft and rods in my GSR with some oversized ITR pistons and was wondering if the people who have done it think its worth it. It would be going in my only car so I guess that I would have some down time and a shop would be doing all the work. So I have a few questions.
1) Is it worth it?
2) About how long would it take for a shop to do?
3) About how much would it cost for the machine work on the block and rods?
Old Aug 29, 2007 | 01:56 PM
all-mtr-teg's Avatar
Default Re: LS crank shaft and rods in a GSR - Is it worth it? (GSR in progress 96)
The machine shop took 2 days once i brought them all the parts. Valve job, resurface head, overbore, balance crank, press in pistons, install arp rod bolts, condition rods, deck the block, assemble block, cost around $600 for labor and machine work. I assemble head and am going to install the head once my custom cometic head gasket arrives in about a week.
Old Aug 29, 2007 | 02:16 PM
mar778c's Avatar
Community Builder
Community Influencer
1) Yes, it is worth it.
2) Time required for a rebuild about 1wk
3) 500 to 600 is about right.
Old Aug 29, 2007 | 03:27 PM
you're building a sleeper ls-vtec. Some say its not worth it cause supposedly you can't rev as high on an ls-vtec as you could on a gsr or type r. But with balancing and arp rod bolts, i don't see why you can't rev to at least 8k rpm safely. Did you read my thread?
https://honda-tech.com/zerothread/1837872
Old Aug 29, 2007 | 11:39 PM
* B A N N E D *
Thanks for the info so far. Does anybody else have any input?
Old Aug 29, 2007 | 11:45 PM
drift4jesus's Avatar
There's no replacement for.....
although it is only going to be 40-60cc total (sorry dont' feel like doing math)
more torque is rarely ever a bad thing.
Old Aug 30, 2007 | 07:29 AM
I've got brand new RM Machines ITR 82mm pistons, hasting rings and wrist pins, and oem ls rods, Asking $185 shipped. all you'll need is an ls crank, mickey33 is selling a clean one here on H-T, already polished for like $150. That would bump you up to like 1870cc or so. I was gonna go 82mm but i found some ls rods w/ 81.5mm itr pistons already pressed in for cheap so i only went 81.5mm. This setup walks over type r's
99gsvtec
18
Jul 26, 2010 03:47 PM
915hondajunkee
Nov 24, 2008 08:37 AM
90da6
Dec 3, 2004 11:37 PM
vtec_yosh
Jun 29, 2004 02:32 AM
Irishweird00
Jun 1, 2003 05:37 PM
