Stainless steel fuel lines
Old Aug 29, 2007 | 10:28 AM
kadidle's Avatar
Default Stainless steel fuel lines
Do russell civic/integra stainless steel fuel lines fit on 5th gen preludes or is there another company out there than makes them for a 5th gen ?
Old Aug 29, 2007 | 10:42 AM
Hawkze_2.3's Avatar
Default Re: Stainless steel fuel lines (kadidle)
I don't think Russell makes stainless fuel lines...they make brake lines.
Do you have a link or any info that shows they make fuel lines?
Old Aug 29, 2007 | 10:52 AM
kadidle's Avatar
Default Re: Stainless steel fuel lines (Hawkze_2.3)
http://www.edelbrock.com/sport...shtml
sorry a thought they were russel there edelbrock but russel is owned by edelbrock
Old Aug 29, 2007 | 12:35 PM
98vtec's Avatar
moderator emeritus
i bought a stainless line 2nd hand that was made by goodridge iirc
Old Aug 29, 2007 | 08:14 PM
Rosko's Avatar
Default Re: Stainless steel fuel lines (98vtec)
russell makes all sorts of fittings, and yes the civic banjo SHOULD fit the prelude. the stud size is the same anyways at least on the fuel rail end of it.
Old Aug 29, 2007 | 08:17 PM
Rosko's Avatar
Default Re: Stainless steel fuel lines (Rosko)
http://www.russellperformance.com/
and heres the fitting itself in the middle of the page...
http://www.russellperformance....shtml
Old Aug 29, 2007 | 08:44 PM
kadidle's Avatar
and the fuel filters are the same right ?
Old Aug 29, 2007 | 08:46 PM
Rosko's Avatar
pretty sure, its been awhile though since I've ran a stock filter.
Old Aug 29, 2007 | 08:47 PM
Hawkze_2.3's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kadidle &raquo;</TD></TR><TR><TD CLASS="quote">http://www.edelbrock.com/sport...shtml
sorry a thought they were russel there edelbrock but russel is owned by edelbrock</TD></TR></TABLE>
I stand corrected I didn't know those were out there..
Old Aug 29, 2007 | 08:50 PM
lude98SH's Avatar
yea they sell SS fuel line in feet and then u cut as needed. Just use the AN fittings and then go AN to metric pitch on the fuel filter or whatever your running to. I guess like -6an would be a good size ?
Old Aug 29, 2007 | 09:07 PM
Rosko's Avatar
Default Re: Stainless steel fuel lines (lude98SH)
yeah -6 is good for most setups. the banjo has a -6 thread on the end of it so a -6 fitting and hose will connect right up to it.
I'd make a kit for it if I still had all that stock stuff to go off of.
Old Aug 30, 2007 | 05:09 AM
lude98SH's Avatar
the stock fuel filter is i beleieve an m14x1.25 if i remember correctly. Id what you would do in the reaer though since its a clip not a fitting back there. Unless you cut the hardline flared it and found the right fitting ?
dacrxguy
Sep 23, 2009 12:04 PM
soundbomber
Jul 26, 2006 02:48 PM
Flamenco-T
Sep 28, 2004 11:32 AM
G-Speed
Jul 9, 2004 12:33 PM
