Integra brake light switch question.
Old Aug 29, 2007 | 07:42 AM
LSracing94's Avatar
Default Integra brake light switch question.
if the brake lights stay on all the time, does that mean the switch could be broken? or if it was broke would the lights not work at all? the plastic piece on the switch is fine. been tryin to figure this out for a buddy for a while now. is there maybe a way to adjust the switch? sometimes the brake light do work and go on and off normally. somtimes they are just stuck on alllllll the time. thanks ahead of time.
Modified by LSracing94 at 10:17 PM 8/29/2007
Old Aug 29, 2007 | 09:17 PM
LSracing94's Avatar
Default Re: Integra brake light switch question. (LSracing94)
wellllllll ok then
Old Aug 29, 2007 | 09:21 PM
PrinceAli132's Avatar
I've seen it go both ways; either not working at all or brake ligts staying on all the time. Try replacing it.
Ali
Old Aug 29, 2007 | 10:25 PM
DC4 Dave's Avatar
It's most likely stuck as result of wear. I've noticed it's more common on East-coast cars that have spent most of their time in humid/damp climates. I know Nissan had an issue with the dust boots tearing prematurely and allowing moisture to get in and corrode the switch, I'm not sure if it's the same deal with older Hondas.
Old Aug 30, 2007 | 06:33 AM
LSracing94's Avatar
Default Re: (DC4 Dave)
good stuff thanks
Old Aug 30, 2007 | 09:29 AM
GSR-TRBO-DA's Avatar
yeah i agree, even though it looks good check it the plasic can still look good but still be broken enough to make the lights stay on. i had the same problem and it was the little plastic peice.
97SS
131
Jul 23, 2021 01:30 PM
geneva
Jun 11, 2008 05:46 PM
PREACHERBREW
Jun 5, 2008 03:47 PM
pythoner
May 21, 2008 11:30 AM
Sarren
Jul 14, 2004 12:32 PM
