help H22a swap EK ... no speed... or blinker
hey guys anyone knowS how to get the speed and blinkers.. working
i just bought a 96 Ek swap with a H22A ... I DON;T KNOW WHAT the GUY before me DID BUT I CAN'T NOT GET THE SPEED sensor TO WORK .. OR THE BLINKERS maybe because THE HAZARD swtich BUTTON IS MISSING ... BUT....
I TRIED USING A HAZARD BUTTON FROM A 95 CIVIC and from a 96 INGETRA BUT IT DOSEN'T WORK EITHER, AS YOU PUSH THE HAZARD SWITCH THE BLINKERS BOTH LIGHTS UP, WITH ALL THE OTHER LIGHTS IN THE GAUGE CLUSTER SEEMS TO LIGHT UP AS WHEN YOU HAVE THE KEY IN THE IGNITION...
NOTE* THE ECU HARNESS HAS BEEN CUT AND IS POORLY WIRED TO A P13 ECU..
AS FOR THE SPEED OR VSS SENSOR WIRE, I TRIED WIRING UP THE VSS WIRE FROM THE CIVIC I BELIEVE TO BE BLU/WHT FROM CONNETOR C ONTO THE P13 ECU IS B10 ORN2
IF ANYONE KNOWS IT WOULD BE GOOD SO I CAN DRIVE IT
this is what it looks like but it needs working
Modified by imperfection_is at 7:25 AM 8/29/2007
Modified by imperfection_is at 7:26 AM 8/29/2007
Modified by imperfection_is at 7:40 AM 8/29/2007
i saw that car forsale lol.but anyways make sure ur vss is good also.i hope u change the look man good luck would like to see what u do to it
I don't know how you messed up your turn signal wiring, that has nothing to do with the engine harness from the swap. Check the fuses for that issue.
For your "speedometer" Check the vss wiring and the wiring behind your cluster. You might have a short or a plug disconnected.
i check eveything i know i even replace the vss and nothing happend i think the gauge cluster might be broken ...
about the blinkers i still dont know, i spent too much time checking... i think the relay might be short on it
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by imperfection_is »</TD></TR><TR><TD CLASS="quote">i check eveything i know i even replace the vss and nothing happend i think the gauge cluster might be broken ...
about the blinkers i still dont know, i spent too much time checking... i think the relay might be short on it </TD></TR></TABLE>
Ya, replace the cluster - it sounds fucked.
If that doesn't work - splice new ends onto the cluster plugs - maybe 6" down the wires.
Shadowz7429
Apr 23, 2007 05:34 AM
strictlyallmotr
May 4, 2005 04:30 PM
NorthWest94Teg
Feb 13, 2004 02:53 AM
wbb6
Apr 9, 2002 05:11 PM
