hi comp pistons with boost?
This one calculator that i looked up says your at 13:1. If thats correct theres no going boost unless you tune on meth or you got a damn good tuner and small small turbo.
if ur gonna sleeve it than swap the pistons out. dont boost a high comp motor. if ur cr is in the 11's ur only gonna be able to run mayb 5 psi which would yeild u a decent hp rating. but if ur cr is higher than 11's i wouldnt boost it cause its probably not going to run on pump gas.
and also what does a jackson racing supercharger run for psi stock.cant decide to go turbo or supercharger with pistons?
00-501itrspec
Mar 18, 2008 06:02 PM
