motor knocking. problem?
Old Aug 29, 2007 | 12:30 AM
skateboard c's Avatar
Default motor knocking. problem?
i havent been driving my hatch for a while but i need to get the car running this week. its a stock d16y7 and the motor is making a knocking sound. the knocking gets louder as i rev and it redlines pretty low. i cant tell where the knocking is coming from but the sound is low when im idling. and back when the problem came up the motor used to shutoff after coming to a complete stop after accelerating. is this problem gonna take a lot of work to fix? should i just swap it?
Old Aug 29, 2007 | 01:24 AM
Solster's Avatar
Default Re: motor knocking. problem? (skateboard c)
if it's slow and deep and seems to go away a soon as you back off the throttle and it's more of a thud it's sounds like a rod and yes you will need alot to fix it. motor swap faster and ezer.
if it's high in tone and rapid it's valve's and i would adj. the valve lash Soon.
Old Aug 29, 2007 | 04:03 AM
Probot's Avatar
Default Re: motor knocking. problem? (Solster)
yea that motor is nearing its end - just went through the same **** a month or 2 ago with my y8 - got worse as i revved and eventually made NO power with alot of knocking and then i heard a loud pop and then parts scattering all over the highway - swap will be painless and alot cheaper - http://www.hmotorsonline.com/s...30021
good luck dude
Old Aug 29, 2007 | 05:44 AM
sql_civic's Avatar
Default Knowledge is good
Yes a swap is easier, but you won't learn as much if you rebuilt it yourself.
Old Aug 29, 2007 | 06:09 AM
Probot's Avatar
Default Re: Knowledge is good (sql_civic)
well if hes got the time and money to tear apart and rebuild a whole motor than yea go for it
Mark Courtney
Jan 3, 2018 11:06 AM
skateboard c
Aug 29, 2007 08:44 AM
typesnick
Apr 28, 2007 12:15 PM
92EG8
Nov 24, 2006 01:41 PM
