fog lights question
Old Aug 28, 2007 | 10:19 PM
BB1LOViN's Avatar
Default fog lights question
i dont know crap about electricals but
does anyone know if its true that 4th gen preludes come with a pre-wired fog light harnes? i see two "light outlets" by the OEM foglight area on my car but i dont know what they are.
anyone with pictures of universal foglights on a 4thgen?
im planning on getting fog lights installed ..any suggestions or things to look out for?
Old Aug 28, 2007 | 11:20 PM
killakayfee's Avatar
Default Re: fog lights question (BB1LOViN)
Yea there is fog light harnesses. I just got JDM foglights for mine. You're going to have to get the mounting brackets for the bumper if they're not there.
Old Aug 29, 2007 | 05:52 AM
HondaFan0504's Avatar
Default Re: fog lights question (killakayfee)
The owner before wired foglights on my 92 Si and did a pretty bad job with it... I can only turn on the fog lights if my headlights are on lol and my foglights aren't even working, I checked all of the connectors, could it be the power relay switch? it makes a click when I switch on and off (trying to turn on the fog lights).
Old Aug 29, 2007 | 05:58 AM
mgags7's Avatar
the harnesses are there, and those connectors are the right ones.
the stock setup requires a subharness and relay and some other bs, and yes, with the honda setup you can only turn them on when the headlights are on.
I just wired mine in parallel with the parking lights.
Old Aug 29, 2007 | 08:57 AM
esedulerp5tenin's Avatar
Default Re: (mgags7)
the 2 connectors behind the bumper signals are indeed the connectors for USDM/JDM foggies, then there's a brown connector taped up near the steering column that you simply plug a relay into, then there is a connector behind the left tweeter cover for the switch for 92-93 ludes, and in 94-96's its under the cup holder.
mostly all the fogs i seen for sale come with the mounting bracket to the bumper, so you shoulndt hafta worry about that. all you gotta do is dremel out the dotted line on the back of the bumper.
voila, factory foggies!!
Old Aug 29, 2007 | 11:01 AM
BB1LOViN's Avatar
great! now all gotta do is find some oem fogs..
will the harness still work with non oem fogs?
Old Aug 29, 2007 | 11:59 AM
MLBZ521's Avatar
Default Re: (esedulerp5tenin)
Anyone have a pictures of said plug near the steering column?? Or at least how many wires and colors that run to it?
I've had a set of JDM Fogs for years, just haven't felt like taking the time to install them because my lower front bumper is all screwed..
Old Aug 29, 2007 | 07:41 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BB1LOViN &raquo;</TD></TR><TR><TD CLASS="quote">
will the harness still work with non oem fogs?</TD></TR></TABLE>
no
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MLBZ521 &raquo;</TD></TR><TR><TD CLASS="quote">Anyone have a pictures of said plug near the steering column?? Or at least how many wires and colors that run to it?
its a brown connector taped up near the steering colum with blue tape, not too hard to find.
JoseCuervo
Lighting
Feb 28, 2012 04:38 PM
Dougie Pants
Honda Fit
17
May 5, 2007 04:07 PM
hamadiscool
Oct 2, 2006 07:14 PM
J.nguyen
Apr 19, 2006 10:40 AM
Acura EL
Aug 11, 2004 06:23 AM
