perhaps an upgrade?
howdy folks...i was thinking perhaps it was time for a fuel line upgrade, but thinking about it now my knowledge on injectors and stuff are not up to par...so i'd like to find out what it would do for the car performance wise and fuel efficiency and just knock the knowledge up a bit, and maybe upgrade soon (if necassary)...so heres the set-up:
B18C1, Skunk 2 intake manifold, STR Throttle Body, Cold air Intake...thats what i have that i would think is of any importance to fuel (a/f)...
any suggestions would be terrific, thanks in advance.
fuel lines will feed up to around 500hp the stock fuel pump can be replaced by a walbro 255 and you should be good. a good fpr can be helpful as the walbro will some times up the fuel pressure and make you run rich.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18c1vicrx »</TD></TR><TR><TD CLASS="quote">well how does this affect the performance and fuel efficeincy?</TD></TR></TABLE> You are using more fuel then you need.
Think
Think
KillAHonDa
May 6, 2008 02:21 PM
Topdawgg
Nov 24, 2006 05:15 PM
