Brake Light stays on???
Old Aug 28, 2007 | 08:16 PM
Dav94Lx's Avatar
Default Brake Light stays on???
Ok so I got into my car one day, and I noticed that my emergency brake light wouldn't turn off even after i released the brake. What do i do to fix this?? I drive a 94 civic sedan. Got any suggestions??
Old Aug 28, 2007 | 09:01 PM
Syndacate's Avatar
Default Re: Brake Light stays on??? (Dav94Lx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dav94Lx &raquo;</TD></TR><TR><TD CLASS="quote">Ok so I got into my car one day, and I noticed that my emergency brake light wouldn't turn off even after i released the brake. What do i do to fix this?? I drive a 94 civic sedan. Got any suggestions??</TD></TR></TABLE>
It's probably one of two things.
1) the wires from the sensor to the cluster are shorting out against the metal some place - check them.
2) The sensor itself is broken/jammed.
Old Aug 29, 2007 | 01:20 AM
BlueIntegraBoy's Avatar
Default Re: Brake Light stays on??? (Syndacate)
3) Low brake fluid level
Old Aug 29, 2007 | 03:45 AM
schwenk's Avatar
Default Re: Brake Light stays on??? (BlueIntegraBoy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueIntegraBoy &raquo;</TD></TR><TR><TD CLASS="quote">3) Low brake fluid level</TD></TR></TABLE>
this one has my vote........9 times otta 10!
Old Aug 29, 2007 | 06:16 AM
ic's Avatar
ic
Default Re: Brake Light stays on??? (schwenk)
visually check fluid
if ok -&gt;
visually check e-brake switch (located under console at base of e-brake handle) make sure not loose/jammed/shorted
if ok -&gt;
get a multimeter
Old Aug 30, 2007 | 09:47 PM
Dav94Lx's Avatar
Cool thanx all. Time to get to work...
Old Aug 30, 2007 | 11:58 PM
EK_kidd's Avatar
I had that problem with my car it was wires touching the frame of my car go find it
Thatssojdm
Feb 26, 2008 08:05 AM
Pabs626
Dec 9, 2007 05:02 PM
darkid10
Feb 10, 2007 01:36 AM
maluseanjohn516
Dec 31, 2005 03:10 PM
ham_yorkwind
Apr 10, 2005 07:43 PM
