91 accord - has power - wont turnover, dead
Old Aug 28, 2007 | 03:40 PM
allsho's Avatar
Default 91 accord - has power - wont turnover, dead
91 accord 2 door exR
-key in
-turn key, its got juice.. everything lights up like normal
-turn once more to start, dead..
Obviously I can take out the starter and put in a new one..
BUT;
Is there anything else common on these cars that may cause it not to turn over at all?
Its weird because the starter hadn't shown any signs of failure.. not like it slowly died or something.
Old Aug 28, 2007 | 04:45 PM
accord99power's Avatar
Default Re: 91 accord - has power - wont turnover, dead (allsho)
want to test it right? get a hammer hit the starter several times then crank and see if it runs, if its a starter you can find the contact off ebay and replace your self instead of buying a whole new starter i saved over $100 bucks and cranks like a dream, lettme kno if u need the website he may still be selling them.
Default Re: 91 accord - has power - wont turnover, dead (accord99power)
ohh wait is your car a manual? i have another test for ya
Old Aug 29, 2007 | 12:43 PM
allsho's Avatar
car is an auto.
Old Aug 29, 2007 | 01:52 PM
Honda-Master's Avatar
chk battery cables for corrosion or looseness.. dead battery ??
also make sure there is power at the solenoid wire at the starter when someone else tries to start the car ,, should get 12 v, and always direct power to the wire coming from the pos battery cable to starter
if you get power on both . most likely you got a bad starter
magpie.1234
Jul 24, 2015 02:19 PM
needhondahelp90
Nov 25, 2014 11:46 AM
Yunggunnazracing
Apr 6, 2014 10:50 AM
killerkali420
Mar 30, 2011 04:29 PM
Grnade
May 11, 2005 11:50 PM
