D16Y7 Engine
Old Jun 14, 2002 | 09:06 AM
Turbo Powa's Avatar
Default D16Y7 Engine
What company makes really good Cams for a D16Y7? Are the engine sizes for the D16Y7 and D16Y8 the same? If so can't you just replace parts from the engine instead of replacing the whole thing to go vtec? What parts do you have to switch? I'm on a really low budget here so I'd be very thankful for some very useful info.
Old Jun 14, 2002 | 09:19 AM
Turbo Powa's Avatar
Default Re: D16Y7 Engine (Civic LX 29)
Anybody?
Old Jun 14, 2002 | 09:39 AM
DOMKID's Avatar
zex makes cams for SOHC. http://www.zex.com. They're pretty good from what i've heard.
Old Jun 14, 2002 | 09:56 AM
Turbo Powa's Avatar
Default Re: D16Y7 Engine (Dominican_Kid)
Thanks!!! Anyone else have any ideas?
Old Jun 14, 2002 | 11:02 AM
methred_92's Avatar
GUDE has one for this particular engine.
I think ZEX cams are only for SOHC VTEC. I could be wrong though.
here are the specs on the GUDE cam.
PART NO.:
HCCS13
DESCRIPTION:
Pulls hard top end.
POWER BAND:
3800 R.P.M. to 7500 R.P.M.
IDLE:
(Good) Around 750 R.P.M.
SPECIFICATIONS:
Intake
LIFT -
0.388
DURATION -
228
Exhaust
LIFT -
0.407
DURATION -
220
Old Jun 14, 2002 | 11:20 AM
autoEXturbo's Avatar
crower makes a nice cam, i'd try them. I've heard mixed reviews about the zex cam, but nothing about the gude.
Old Jun 14, 2002 | 11:29 AM
mlhardy's Avatar
The block is the same you could just swap the head for a Y8 or you could throw a Y5 head on. The Y5 has roller rockers and is pretty much a built head.
Old Jun 18, 2002 | 11:29 AM
Turbo Powa's Avatar
Default Re: D16Y7 Engine (mlhardy)
Swap just tha head? Wouldnt I need to replace just more than the head to get better performance?
Old Jun 18, 2002 | 11:31 AM
Spade's Avatar
To start you can swap just the head and get the VTEC yo!
ROFL........that will help out, then you can just get a VTEC cam.
Old Jun 18, 2002 | 11:42 AM
Turbo Powa's Avatar
Default Re: D16Y7 Engine (Spade)
I'd have the to buy a complete head right? I cant just swap the head without getting new intake manifold with throttle body? Or can I just swap the head.
Old Jun 18, 2002 | 12:07 PM
sohc_boy's Avatar
u could use your stock intake manifold but it will probably hinder your performance a bit compared to the y8 intake manifold, which is considered the best for the sohc.
Old Jun 18, 2002 | 12:28 PM
Turbo Powa's Avatar
Default Re: D16Y7 Engine (sohc_boy)
how will the vtec be activated?
Old Jun 18, 2002 | 12:42 PM
JDMvtecDRAGSTA's Avatar
if you use a vtec head youll need more than just head.
you need the wiring to be done.
vtec head.(and ALL its components)
vtec ecu
if you dont want to spend i suggest not doing this swap.
but one thing you can consider is changing the throttle body and intake manifold from your y7 to a y8.
theres a lot of things you can do to ur motor just gonna cost you a grip
Old Jun 18, 2002 | 12:46 PM
Turbo Powa's Avatar
Default Re: D16Y7 Engine (sohcmydohc)
thanks!
Old Jun 19, 2002 | 04:59 AM
sohc_boy's Avatar
u can also use an rpm activated switch to engage vtec.
Old Jun 19, 2002 | 05:10 AM
ZUL8R's Avatar
Default Re: D16Y7 Engine (methred_92)
im lookin for something else to do to my DX. Whats the site foe GUDE. i want to do the intake and throttle swap. my buddy is puttin a new engine in his ex. he said i could have the intake manifold and throttle body. it had 170,000 harsh miles so could the intake be damnaged at all. the head i dont want most likely.
[Modified by shane Z, 9:11 AM 6/19/2002]
Old Jun 19, 2002 | 05:44 AM
Koori's Avatar
Default Re: D16Y7 Engine (autoEXturbo)
I'd go with Crower, in fact, I did. I didn't go the all motor route but here's my mods on my D16Y8... I think the Y7 is non-vtec for a DX/LX rated at 106hp.
Comptech Header
Apex'i WS Exhaust
Jackson Racing Super Charger
Crower Cam
AEM Underdrive pulleys (Don't get those!)
AEM CIA
Intake manifold Ported and Polished
80mm Throttle Body
With these mods minus the supercharger, I'm running in the high 120's horsepower at the wheels. I'm not exactly sure because I haven't dynoed for a while. It's not the fastest all motor but it's fun and it doesn't attract unwanted attention.
[Modified by Hadji, 9:48 AM 6/19/2002]
Old Jun 19, 2002 | 05:50 AM
Default Re: D16Y7 Engine (Hadji)
have you taken your car down to the track with your supercharger?, if so what times did you pull? What don't you like about the AEM pulley kit. I haven't noticed anything bad, except i didn't feel a real power gain, just that it climbed the power band quicker. Also, which cam did you get, and has it helped out alot? I know there were different stages.
[Modified by autoEXturbo, 2:51 PM 6/19/2002]
Old Jun 19, 2002 | 10:28 AM
Turbo Powa's Avatar
Yea which cam DID u get?
Old Jun 19, 2002 | 10:33 AM
EVIL Hx Coupe's Avatar
who makes a cam for the D16Y5????
turnsignalandy
Apr 9, 2006 03:12 PM
young noob
Mar 21, 2006 11:21 AM
MrTodd
Aug 23, 2003 10:14 AM
ranger4
Aug 23, 2002 03:58 PM
GapxGuy
May 9, 2002 09:20 AM
