RADIATOR CORE SUPPORT HOW TO...NEED HELP PLEASE!!!
Old Aug 28, 2007 | 02:14 PM
tx95excoupe's Avatar
Default RADIATOR CORE SUPPORT HOW TO...NEED HELP PLEASE!!!
Does anyone have a how to on how to change the radiator core support out on a 95 ex coupe? Also will the radiator core support on any model of 92-95 civic fit a 95 ex coupe? I also thought of dong the Integra front end conversion since I have to change the front end anyway. Which one would yall recommend, and which one would be easiest, or are they both about the same as far as labor goes?
Old Aug 28, 2007 | 02:37 PM
philosofy1's Avatar
Default Re: RADIATOR CORE SUPPORT HOW TO...NEED HELP PLEASE!!! (tx95excoupe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tx95excoupe &raquo;</TD></TR><TR><TD CLASS="quote">Does anyone have a how to on how to change the radiator core support out on a 95 ex coupe? Also will the radiator core support on any model of 92-95 civic fit a 95 ex coupe? I also thought of dong the Integra front end conversion since I have to change the front end anyway. Which one would yall recommend, and which one would be easiest, or are they both about the same as far as labor goes?</TD></TR></TABLE>
i am in the same process you are, but on a 89 accord. it's not an easy job, but quite tediuos. wish you the best and be patient.
oh, and yes, any 92-95 civic front radiator support will work.
Old Aug 28, 2007 | 02:54 PM
vtecftw's Avatar
get a spot weld cutter and go to town+
Old Aug 28, 2007 | 04:19 PM
slowcivic2k's Avatar
Used an air chisel on my 2000 coupe, takes it off in a matter of minutes, might need a manual chisel to create a start point for the air gun. Mine is also held in by 2 (could be 4) bolts that actually hold it to the frame rails.
B16Civic93
Mid-Atlantic (Sales)
Aug 27, 2009 02:31 PM
JDean6pac
Welding / Fabrication
Apr 12, 2007 04:52 AM
handa
Apr 14, 2004 08:54 AM
GunnaGetOne
Sep 29, 2003 11:32 AM
