hondabond necccesary for valve cover gasket?
Old Aug 28, 2007 | 02:14 PM
20ls01's Avatar
Default hondabond necccesary for valve cover gasket?
i plan on doing a valve adjustment, someone said it is a good idea to replace the valve cover gasket, and im going to do that. do i need to apply honda bond on the gasket?
Old Aug 28, 2007 | 02:16 PM
myfirstdc2's Avatar
Default Re: hondabond necccesary for valve cover gasket? (20ls01)
its recommened that u use honda bond. its a good idea to use if u dont have honda bond hi temp silcone is ok too
Old Aug 28, 2007 | 03:05 PM
goota's Avatar
Yes you have to use it. Do it Once, Do it Right.
Old Aug 28, 2007 | 03:26 PM
CleanLikeJdm's Avatar
Hype-R Stalker
Default Re: (goota)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by goota &raquo;</TD></TR><TR><TD CLASS="quote">Yes you have to use it. Do it Once, Do it Right.</TD></TR></TABLE>
You don't have to use it .. It's mostly recommended for the sides of the cams anyways.
But if you clean the surface properly, it works fine, and if it's not the First vc gasket,
you can normally reuse them if they look to be in good shape.
Old Aug 28, 2007 | 03:49 PM
PACT man's Avatar
Default Re: (CleanLikeJdm)
You only need to put some in the corners where the cam caps arch over, you are not supposed to need to put it anywhere else(as per recommended procedure by Honda). You need to clean the mating surface on the head and there should be no reason why the gasket will leak.
sorwdfish
Feb 3, 2013 08:42 AM
2k_Si
Feb 16, 2009 07:03 AM
rasinhell
Aug 8, 2005 01:00 PM
E-spec Tuner
Apr 17, 2003 09:16 AM
hb_racer
Aug 4, 2002 11:58 AM
