Honda S2000 Honda S2000
shakes REALLY BAD as u accelarate HELP!!!
Old Aug 28, 2007 | 02:12 PM
ruracer18's Avatar
Default shakes REALLY BAD as u accelarate HELP!!!
i have a 04 s2000 and i just noticed as i accelerate on the highway going about 70mph-80mph it shakes really bad, its not balance on tires, i know for sure i can tell when balance is off or bad, this has to be something else.
Old Aug 28, 2007 | 04:57 PM
g2kap1v2's Avatar
i had similar experiences when my car was out alignment. does the shaking continue when you cruise at a steady 80 mph?
Old Aug 28, 2007 | 04:59 PM
S@nt0s's Avatar
Munkyw3rkz.webs.com
Default Re: (g2kap1)
worn tires
bad alignment
wheel balance
bad axels
axel nut
Old Aug 28, 2007 | 05:02 PM
- BSeRiouS -'s Avatar
is your car lowered? Worn CV joints possibility
Old Aug 29, 2007 | 09:31 AM
Yosshaa's Avatar
cv joints ftl
Old Aug 29, 2007 | 03:52 PM
ruracer18's Avatar
yea as u drive steady 80mph it keeps on doing that, slow back down and its all good.
Old Aug 29, 2007 | 03:58 PM
ruracer18's Avatar
Default Re: (I BSeRiouS I)
yeah the car is lowered, -1.5" springs, i put spacers on the axles but only about 3 months later when i found out u need them there.
Old Aug 29, 2007 | 04:56 PM
S@nt0s's Avatar
Munkyw3rkz.webs.com
Default Re: (ruracer18)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ruracer18 &raquo;</TD></TR><TR><TD CLASS="quote">yeah the car is lowered, -1.5" springs, i put spacers on the axles but only about 3 months later when i found out u need them there. </TD></TR></TABLE>
you dont "NEED" but are recommended.. i drove mine over 1.5 years pretty low and didnt have any of the "shakes" from the early short axel
Old Aug 29, 2007 | 05:21 PM
Default Re: (S@nt0s)
im calling worn CV joint cups. Swap those from left to right and you should be golden. If not, torque down your rear axle nut to 215 ft lbs (i think) although, I do find tis weird since you have an AP2. This is usually an AP1 thing
Old Aug 29, 2007 | 05:42 PM
g2kap1v2's Avatar
go to honda and have them check your alignment. they won't charge anything if alignment is up to par, but if any of the wheels is off they will tell you and you will have to get it done right there.
Old Aug 29, 2007 | 07:04 PM
frankdatank's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by I BSeRiouS I &raquo;</TD></TR><TR><TD CLASS="quote">im calling worn CV joint cups. Swap those from left to right and you should be golden. If not, torque down your rear axle nut to 215 ft lbs (i think) although, I do find tis weird since you have an AP2. This is usually an AP1 thing</TD></TR></TABLE>
i think its the cv joibts too. does it only happen when your on the throttle? is it only at higher speeds?
Old Aug 30, 2007 | 11:56 AM
ruracer18's Avatar
Default Re: (frankdatank)
keeps on doing it if gas pressed or not just driving 70 or above, i had the car for a year now, drove around lowered for about 6months, put the shaft spacers on about a month ago, im sure it started shaking as soon as i put the spacers on or sometime there. the shafts that stick out of differential move around a lil, is that bad.
xlasianizelx
Suspension & Brakes
Sep 13, 2009 08:14 PM
TEGGRY
Sep 5, 2007 09:47 AM
VTECcnIT
Feb 21, 2006 06:46 PM
Eg_Ryan
Oct 21, 2005 09:22 AM
wdyno
Apr 16, 2002 11:13 AM
