F'ing Swap!!!!!
So I have been working out all the bugs from my motor swap. I got rid of all the check engine codes. The motor has spark and fuel (check at injectors). The damn thing still won't run.
My buddy came over yesterday with a compression tester and all 4 cylinders read 27psi. At first I was super pissed because this motor was suppose to be a good motor. Then I began thinking what would cause this.
Usually when a motor is bad you get knocking, clanking, noise from it. The motor is as smooth as can be when cranking. Also when a motor is bad it is usually 1 cylinder that has extremely low compression, right????
What do you guys think?? It wierds me out that all 4 cylinders are reading the same extremely low compression.
Is the timing off slightly where a valve is opened just enough to leak out the compression and not hit the pison????
Any advice or help would be great.
Leon
Leon
What does the timing look like??
If you dont know how to set the belt, check this out:
http://www.c-speedracing.com/h...t.php
Do a leak down test. With your compression gauge should be an adapter so that you can run compressed air via the spark plug fitting that you use for the compression check. Put cylinder #1 at Top Dead Center and give it some air. If there is significant leakage out the exhaust, those valves are bent and/or the timing is off. If it's the intake, then same thing. If this is the case, double check your timing. The easy way for #1 is to put a long screwdriver in the spark plug hole and manually turn the crank until the screwdriver comes to the top. Now, check the cam gears and see if the notches on the gear (9 o'clock and 3 o'clock) line up with the head (level with the head surface). If so, bent valves, if not, your mechanical timing is out of specification. Reset your mechanical timing and turn the motor with a wrench, spark plugs out to make sure you don't have any interference with the valves and pistons. If all checks out, put the spark plugs in and make sure the firing order is correct. Remember #1 is closest to the crank pulley and #4 closest to the transmission. Hopefully, if all is wired right, she'll go vroom and not boom.
JDM_EK_JOE
Oct 22, 2007 07:11 PM
Circuit Star-29
Apr 22, 2005 11:51 AM
