FS/FT: 1993 Del Sol Si b18a1 Gsr Trans S.E.-PA
Its that time, just got it done and now i am selling it. $4250
or trade for something with more seats
IE: DA 4dr/2dr, clean sedans, hatches
Perfect for LS/VTEC or Boost
Engine:
B18a1
OBD1 running Obd0 injectors with resistor box
New Water pump
T-belt
Head Gasket
Rear main
Crank seal
ARP head studs
EGR block-off plate
PR4 Ecu no CELs
Trans:
94+ Gsr trans w/ 6 puck clutch
Band new axles
Suspension:
Tokiko Advanced Suspension kit (blue)
Exhaust:
2 1/4 all the way from the header
stainless axleback with mild steel mid everything else
no cat on it but will install one or include it (choice)
Brakes:
Stock, need new pads ( 4 fresh blank rotors included front and rear)
Exterior:
small patch of rust, see pic.
Yellow AUX fog lights
Rota Slipstreams wrapped in Falken ZE 512 (30%)
Has an OEM wing (not Pictured)
Interior:
9.2/10
tiny rip on the side bolster of the driver seat
Clean carpet
1993 Driver side air bag only
Pics:
Modified by highrev1987 at 1:47 AM 8/29/2007
Modified by highrev1987 at 1:52 AM 8/29/2007
Engine:
B18a1
New Water pump
T-belt
Head Gasket
Rear main
Crank seal
ARP head studs
EGR block-off plate
PR4 Ecu no CELs
Trans:
Band new axles
Suspension:
Exhaust:
Brakes:
Exterior:
Interior:
9.2/10
Clean carpet
Pics:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Gold DA9 »</TD></TR><TR><TD CLASS="quote">Bump for another Sol</TD></TR></TABLE>
thanks
thanks
Bump b/c I looked and I go to WCU
Put some rust inhibitor on that before it gets any worse. It doesn't fix it but it slows it down drastically
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EH2palmyblueSIR2 »</TD></TR><TR><TD CLASS="quote">Bump b/c I looked and I go to WCU
thanks
</TD></TR></TABLE>thanks
highrev1987
Sep 3, 2007 06:36 PM
