ecu question
if i have a odb2 h22 and a chip p28 which compter will work better . If i get a set down to an odb1 computer will that work better than a chip compter(p28). I want to still be able to check my check engine light
2002 honda accord 5 spd
the P28 will not work with your car unless you have a jumper harness..they go for around 80-130 bucks....and yes you can check you CEL the ame..the chipped P28 allowes you to tune your car...
which is better a odb p13 or chipped p28 and how will i be able to get inspection when the check the odb2 port and i know i have to convert to odb1 alraedy
