Lookie what I made! Skid plate for the ITR header
Old Aug 28, 2007 | 07:19 AM
mac_24_seven's Avatar
Default Lookie what I made! Skid plate for the ITR header
Made out of 3/16 ,5052 marine grade aluminum. Weighs almost exactly 2 lbs.
Figured you fabrications guys (some anyway) might appreciate it. Easy to do, I know, but fabricated none-the-less
Old Aug 28, 2007 | 07:57 AM
nonsense's Avatar
Default Re: Lookie what I made! Skid plate for the ITR header (mac_24_seven)
that reminds me of something
http://www.fastlineperformance.com/skidplate.htm
Good job with the DIY fab though. I'm sure it cost you less than $60. I'd probably radius the corners just for a little more of a "professional" look to it.
Old Aug 28, 2007 | 08:55 AM
Default Re: Lookie what I made! Skid plate for the ITR header (nonsense)
I've thought about that Just might do it to the next one.
Old Aug 28, 2007 | 09:10 AM
Eddiebx's Avatar
their's is superior by 1/16"
Old Aug 28, 2007 | 09:42 AM
Default Re: (Eddiebx)
And by almost $30.00 too
I'm happy with it.. it came out real good. I'll get one on my car Wednesday if I can so you can see some installed pics in a car.
Old Aug 28, 2007 | 10:46 AM
Andrew Marquis's Avatar
Heres pics of mine installed.
Gee.. I wonder what compelled me to take the ITR header off??
(btw, mac_24_seven is my brother and bummed my plate to generate his own.)
Old Aug 28, 2007 | 12:04 PM
hondacivic00's Avatar
skid plate looks good but doesn't that hang REALLY low??
Old Aug 28, 2007 | 12:12 PM
Default Re: Lookie what I made! Skid plate for the ITR header (hondacivic00)
The header is on a b16 in a lowered CRX. His car is just too low. He put the OEM b16 header on there and its just fine now.
Not the plates fault.
Old Aug 28, 2007 | 12:34 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mac_24_seven &raquo;</TD></TR><TR><TD CLASS="quote">The header is on a b16 in a lowered CRX. His car is just too low. He put the OEM b16 header on there and its just fine now.
Not the plates fault.</TD></TR></TABLE>
Yep. Since the B16's are kinda 'shorter' in general in comparison to the 1.8's, plus the extra little bit for the 4-1 design... yeah... it hung low.
Old Aug 28, 2007 | 01:24 PM
LSEGHATCH's Avatar
Default Re: Lookie what I made! Skid plate for the ITR header (Andrew Marquis)
I'd do something about the bolts. If you bottom out a couple times there might not be anything left of the heads.
Old Aug 28, 2007 | 07:36 PM
uselesshuman's Avatar
Default Re: Lookie what I made! Skid plate for the ITR header (LSEGHATCH)
yup i was just gonna say you should contersink the heads of those bolts
Old Aug 29, 2007 | 10:44 AM
Or just use pan-head bolts...
I guess it's better than nothing. Countersinking would be prime, though
Old Aug 29, 2007 | 11:30 AM
Default Re: (Andrew Marquis)
Pan head bolt?
Never heard of em... And countersinking is a good idea.. Only problem is it kills any adjustment.
Old Aug 29, 2007 | 06:03 PM
MajorPayne's Avatar
Default Re: (mac_24_seven)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mac_24_seven &raquo;</TD></TR><TR><TD CLASS="quote">Pan head bolt?
Never heard of em... And countersinking is a good idea.. Only problem is it kills any adjustment.</TD></TR></TABLE>
if you use a tapered head bolt then make the groove tapered, it would still have adjustment and be hidden
but to do that correctly that would require a mill, which you may or may not have access to
Old Aug 29, 2007 | 06:25 PM
Default Re: (MajorPayne)
I don't have access to that, unfortunately.
:S
And somebody link me to a place that sells panhead BOLTS. I can find screws, but not bolts that take a socket.
Old Aug 31, 2007 | 10:43 AM
nonsense's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mac_24_seven &raquo;</TD></TR><TR><TD CLASS="quote">And somebody link me to a place that sells panhead BOLTS. I can find screws, but not bolts that take a socket.</TD></TR></TABLE>
I think they may have meant "Flat Head Socket Cap Screws" search mcmaster.com
something that looks like this:
Old Nov 29, 2007 | 06:34 AM
green eyed bandit's Avatar
This skid plate looks identical to the plate that fastline performance sells. I need one though.
Old Nov 29, 2007 | 02:28 PM
CagedRuss's Avatar
A button head would work good for that also. First time scraping it though could make it a bitch getting a Allan into.
Old Nov 29, 2007 | 02:37 PM
Default Re: Lookie what I made! Skid plate for the ITR header (green eyed bandit)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by green eyed bandit &raquo;</TD></TR><TR><TD CLASS="quote">This skid plate looks identical to the plate that fastline performance sells. I need one though.</TD></TR></TABLE>
Terrance (OP) sells them for $40 shipped. Thats less than 1/2 the cost of Fastline's price.
Check his sig
Old Nov 29, 2007 | 02:59 PM
nonsense's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Andrew Marquis &raquo;</TD></TR><TR><TD CLASS="quote">
Check his sig
good math skillz there. Less than 1/2 would be less than $29.50, not $40
If it looks like the one in his pics above it's worth spending the $19 extra on the Fastline one.
mannys90crx
Dec 19, 2010 11:11 AM
2.0L EK
Dec 18, 2007 02:28 PM
S9i1R
Welding / Fabrication
10
May 21, 2007 09:58 AM
JDM CTR '00
Jul 20, 2004 05:12 AM
ITR607
17
Nov 24, 2002 10:35 PM
