SiR front break question...
so i can get SiR front hubs/brakes for $175 and just had a question... if i went to an auto parts store to get new disks and pads... what would i buy em for? or are they different from anyting a parts store would have?
Modified by EFstyle at 11:51 AM 8/28/2007
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EFstyle »</TD></TR><TR><TD CLASS="quote">so i can get SiR front hubs/brakes for $175 and just had a question... if i went to an auto parts store to get new disks and pads... what would i buy em for? or are they different from anyting a parts store would have?
Modified by EFstyle at 11:51 AM 8/28/2007</TD></TR></TABLE>
the SiR knuckles are the same as 90-91 civic ex knuckles. they use 10.3" rotors, which you can find on any 90-01 integra, 99-00 si, 90-01 civic ex. the pads you'll need are from the 90-91 civic ex. $175 for SiR knuckles is steep, does that include s/h as well? sir knuckles for $175, the 90-93 integra or 90-91 civic ex knuckles would cost much less in a local junkyard. you can also use the knuckles from any 94-01 integra as well, they use a bigger caliper stamped 17CL14VN. when buying knuckles online (or imported), keep in mind that you will not be able to inspect it before purchasing, they could be selling you a set-up (w/ bad bearings or hubs, seized calipers, etc), which could end up costing you more money in the end.
no shiping they are from a friend that got em off password i guess... i was interested in em cause my wheel bearings are **** anyways... should i just not bother with it and get new wheel bearings pressed in? i might also need ball joints and such on my stock Si's... thats why i was considering the SiR's...
90-93 teg pad rotors and wheel bearings
http://www.angelfire.com/ca/DrOhm/SiRkuckles.html/
http://www.angelfire.com/ca/DrOhm/brakes.html
so my Si axels will or will not fit into the SiR hubs? if i got the SiR hubs... the wheel bearsings and such are fine... if i keep my Si hubs... then i gotta get bearings and balljoints...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EFstyle »</TD></TR><TR><TD CLASS="quote">no shiping they are from a friend that got em off password i guess... i was interested in em cause my wheel bearings are **** anyways... should i just not bother with it and get new wheel bearings pressed in? i might also need ball joints and such on my stock Si's... thats why i was considering the SiR's...</TD></TR></TABLE>
the ones on your Si are the DX knuckles, they're found on 88-00 civic. the SiR's are almost identical to the civic EX/ 90-93 integra knuckles, dump your DX's...
https://honda-tech.com/zerothread?id=1104305
the dx uses a 9.4" rotor w/ smaller calipers, the 90-91 civic ex/90-93 integra & SiR knuckles use 10.3" rotors w/ bigger calipers.
Modified by roastbeefrichie at 7:47 PM 8/28/2007
Modified by roastbeefrichie at 9:04 PM 8/28/2007
Devil CRX
Oct 8, 2009 09:33 AM
virginia_dude
Oct 4, 2005 02:06 PM
Type V
Aug 26, 2005 12:33 PM
virginia_dude
12
Mar 22, 2004 10:07 AM
