B-series oil pump install question (97 Gsr)
Old Aug 27, 2007 | 09:19 PM
all-mtr-teg's Avatar
Default B-series oil pump install question (97 Gsr)
When installing the oil pump onto the crank, the inside of the oil pump hole where the nose of the crankshaft goes through, has a flat grove and then across from it there is a flat groove with a semi circle notch. Does that flat grove with the semi circle notch go over the side of the crankshaft nose where the woodruff key sits? I forgot which side is which when i took it off a month ago.
Old Aug 27, 2007 | 09:52 PM
Hybrid96EK's Avatar
Default Re: B-series oil pump install question (all-mtr-teg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by all-mtr-teg &raquo;</TD></TR><TR><TD CLASS="quote">When installing the oil pump onto the crank, the inside of the oil pump hole where the nose of the crankshaft goes through, has a flat grove and then across from it there is a flat groove with a semi circle notch. Does that flat grove with the semi circle notch go over the side of the crankshaft nose where the woodruff key sits? I forgot which side is which when i took it off a month ago.</TD></TR></TABLE>
As far as I know, it doesn't matter how the notch lines up... Unless someone else knows something I don't. I've never seen anything regarding this online or in the Helm.
Old Sep 29, 2010 | 06:30 PM
Defiant_dc's Avatar
Default Re: B-series oil pump install question (97 Gsr)
(bump) Anyone know the answer to this question?? I'm installing an oil pump and i dont want to get it wrong =/
Old Sep 29, 2010 | 06:43 PM
PyroProblem's Avatar
It shouldnt matter.
Old Sep 30, 2010 | 08:04 AM
Defiant_dc's Avatar
Cool, thanks!
phyzJunkieCivic
Nov 7, 2006 01:09 PM
OrangeBoost
May 19, 2006 06:23 AM
JDM JEFFREY
May 9, 2005 09:21 AM
SleepyHF
Mar 15, 2004 08:26 PM
ALLMOTORJ
May 24, 2003 08:07 PM
