Getting ready to paint. What should i look out for and any tips?
IF YOU DONT LIKE THIS PLEASE LEAVE NOW AND DONT COMMENT. KEEP UR NEGATIVES TO YOURSELF. Once that said ill go on and start.
Today i went out to buy some new OEM paint for my car. A friend reccomended me to PPG. so i went there. Gave em my color code and bought my 2quarts of paint, 1gallon of reducer,2 8oz bottles of hardener, 2 quarts of clear. This will be my first time paint a car. well ive done spray can nd stuff , but not air wise. Only reason i want to paint it myself is just to save some money.I got the Air compressor, air spraygun and paint. is their a tip i should know? i will be painting this in my garage. i will cover up the walls and have a fan ready. What tips do you guys give to a newb painting. What should i watch out for. any help would be greatful. thanks
Got my Paint from PPG:
SPRAY Gun From walmart
for 58.98. thot i give it a try.
Update. buddy of mines fixed all the tiny dents, big dents, etc. didnt use much bondo so that was kool.
ALSO GOT MY J's replica lip in while me and my buddy was sanding the car
didnt screw it on but heres a test fit....
Other buddy came through with his Gixxer750:
UPDATE 8-30-07 > wetsand the entire car today with two friends. 6 hands can sand fast hahaha
Nephew came over with these signs lol thot i just put it on for fun
UPDATED PICS ON PAGE 2
Modified by Ef YU at 8:26 PM 8/28/2007
Modified by Ef YU at 8:27 PM 8/28/2007
Modified by Ef YU at 8:28 PM 8/28/2007
Modified by Ef YU at 3:13 AM 8/31/2007
Modified by Ef YU at 3:14 AM 8/31/2007
Modified by Ef YU at 1:01 AM 9/5/2007
I don't mean to smash you but.. did you get that spray gun kit from Walmart
Make sure you prepped well, stay the same distance away from the vehicle, good speed... follow flash times i guess
Thanks for the TIP!! and yeah its from walmart hahaha . as stated above in da pic. but i thot i give it a try. my brother has another gun, just thot i mite buy one for myself.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mztykal »</TD></TR><TR><TD CLASS="quote">Why didn't you get MC161? It's a pretty good first timer's clear.
It's very forgiving and really hard to run. </TD></TR></TABLE>
I dunno much about paint. the guy at the sop said this paint should be good enough for your first time.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EG-Kaos »</TD></TR><TR><TD CLASS="quote">remember to degrease all the surfaces and bleed your compressor to have it free of water, don't wanna get the nasty fish eyes in that nice paint </TD></TR></TABLE>
Thanks. will do.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by reactone »</TD></TR><TR><TD CLASS="quote">I hope that you're planning on/already purchased a decent respirator.</TD></TR></TABLE>
Yeep. got a old one but need to buy a new filter.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MEAN88Si4WS »</TD></TR><TR><TD CLASS="quote">subscribed.
SPRAY IT ALREADY!!!!!!!!!!!</TD></TR></TABLE> Gotta fix the dents b4 n e thing goes on it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 401B18TEG »</TD></TR><TR><TD CLASS="quote">i want to see the outcome of this. SPRAY IT</TD></TR></TABLE>
Will DO
UPDATES PICS ARE POSTED TOO..
Thanks. will do.
Will DO
Make sure that you mix everything correctly, not too much and not too little. remember, the paint will only be as smooth as prep work under it. make sure you wetsand the primer with 600 or 800 grit. allow it the dry completely before spraying the base. I forgot what kind of clear that I got but I should have gotten the stuff that you have. My clear was hard to spray, hard to get it to lay down smooth and not run. make sure you use a sanding block too, helps keeps things level.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Genuine Rolla »</TD></TR><TR><TD CLASS="quote">Make sure that you mix everything correctly, not too much and not too little. remember, the paint will only be as smooth as prep work under it. make sure you wetsand the primer with 600 or 800 grit. allow it the dry completely before spraying the base. I forgot what kind of clear that I got but I should have gotten the stuff that you have. My clear was hard to spray, hard to get it to lay down smooth and not run. make sure you use a sanding block too, helps keeps things level. </TD></TR></TABLE>
Thanks for the great tip.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SneezinCD5 »</TD></TR><TR><TD CLASS="quote">I would of recomended the PPG DCU2021 for clear. It lays out really nice and is easy to spray. I haven't been that impressed with the OMNI line.</TD></TR></TABLE>
Me neither...I used some Omni clear on my car and I found it hard to get it to lay down smooth and its not all that resistant to dripping. It seemed like I couldn't get the atomization down correctly no matter how long I spent getting the pattern right.
From: Streets of Sacramento...But now living in So Cal, usa
omni is a generic line made by ppg. and yea the omni clear are shitty too imo but then again if you know what your doing and know how to adjust you gun correctly you should have no problem laying down any brand of clear.
Thanks for all the greatful tips you guys. greatly appreciated.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blue k7 »</TD></TR><TR><TD CLASS="quote">forget the car that bike is sick!
for waiting on the finish
haha your gonna help me wet sand the bitch lOl
</TD></TR></TABLE>haha your gonna help me wet sand the bitch lOl
how do u bleed an air compressor to get water out? because i always get fish eyes with mine and my oil/water removers fill up fast as hell.
</TD></TR></TABLE>how do u bleed an air compressor to get water out? because i always get fish eyes with mine and my oil/water removers fill up fast as hell.
