Oil Pan Leak
Old Aug 27, 2007 | 06:19 PM
kornerk12's Avatar
Default Oil Pan Leak
My oil pan is leaking it looks like there is a hole that should have had a bolt in it but doesnt have one. This is a 5th gen with an aluminum pan. The hole is on the drivers side almost on the end of the pan. I was wondering if something is supposed to be screwed in that hole or its supposed to be like that and its just leaking from somewhere else around that ? any pics would be great thanks
Old Aug 27, 2007 | 09:13 PM
Mike1995HondaPrelude's Avatar
Default Re: Oil Pan Leak (kornerk12)
Same thing happened to me. The mechanic said that hole is meant to be there. Check your oil pressure switch.
Old Aug 28, 2007 | 05:54 AM
kornerk12's Avatar
Default Re: Oil Pan Leak (Mike1995HondaPrelude)
nope not the oil pressure switch thats further to the right (towards the passenger side) but i checked it anyway and no leak. What was your leak coming from ?
Old Aug 28, 2007 | 05:58 AM
Acidcrakker's Avatar
I just had my oil leak fixed the other day. It turned out that the oil gasket was bad and oil was spilling out of there. Mabey that helps you.
Old Aug 28, 2007 | 06:02 AM
kornerk12's Avatar
Default Re: Oil Pan Leak (acidcrakker)
i believe the 5th gens dont use a gasket just hondabond however the 4th gens do use a gasket however they are not aluminum pans i believe. Correct me if im wrong ...
Old Aug 28, 2007 | 06:52 AM
117's Avatar
117
The 5Gen does use a very small oil pan gasket. It's on the back of the block (i.e. on the passenger side of the block as it sits in the car). The gasket only seals the curved part of the pan. The rest of the pan is sealed with Hondabond.
cletus11
Jan 14, 2012 12:49 PM
Bobby_Budds
May 18, 2010 11:10 PM
Mattyg2
Aug 28, 2004 04:50 PM
LAKER HATER
May 21, 2004 07:51 AM
Pinhead
Jun 9, 2002 01:53 PM
