Performance General Performance oriented Parts (Ex: Camshafts, Electronics, Air Intakes, Exhausts, complete engines)
Skunk2 blowout sale!!!! cheap !! ready to ship !!
Old Aug 27, 2007 | 05:45 PM
tunerzimage's Avatar
Banned
Default Skunk2 blowout sale!!!! cheap !! ready to ship !!
In stock Skunk 2 Racing Products!! We will match or beat any advertised price, lowest prices guaranteed!
Skunk2 Pro-Series high performance coilovers are based on over a decade of racing and suspension tuning experience. The advanced technology we have used in numerous road racing and drag racing championships is now being applied to our new line of Pro-Series coilover suspensions. Skunk2’s track and street tested valving offers the perfect balance for the daily drive or for spirited performance driving. Pro-Series coilovers feature shortened shock bodies and shortened shaft strokes so suspension travel can be maintained on lowered vehicles for improved performance and comfort. With Skunk2 coilovers, enthusiasts can quickly and precisely set ride heights and corner weights to improve the vehicle’s handling response, cornering ability, stability, and balance. Our full coilover suspension is offered in our nonadjustable dual-tube PRO-S design, or our PRO-C adjustable mono-tube design. Skunk2 coilovers include hard anodized CNC-machined forged 6061-T6 spring perches and Skunk2 CNC-wound racing springs made from SAE9254V spring steel.
PRO- S coilovers NOW AVAILABLE!
# Dual Tube Design
# Non-Adjustable Precision Valving
# Shortened Shock Body and Stroke
# Adjustable Ride Height
# One-Piece Machined Bodies
# Uses Factory Upper Mount
# Some Kits include Forged Mounts
# SAE9254V Racing Springs
$ 600 shipped!!!
applications - EG, DC, EK
88-00 Civic/Crx/Del Sol; 90-01 Integra Part# 541-05-5700
ON SALE! PRO-S suspension only for EF/DA applications
starting at $499 shipped please call for sale price ( HT price ) ask for MILES !
PRO-C suspension
$1050 shipped! please call for application! - EG/DC, EK, EF/DA
Pro Series Intake Manifolds:
* Increased Plenum and Runner Size
* Oversized Throttle Body Opening
* Made From High-Grade 356 Aluminum
* OEM Quality Shell Molded Casting
* Nitrous Mounting Bungs
* Skunk2 Acid-Etched Nameplate
* Broadest Usable Powerband
* Vacuum Tested To Ensure Quality
* Utilizes Stock Sensors 64mm Throttle Body Opening That Can Be Port Matched To 75mm
* Increased Plenum Volume
* 8” Tapered Runners For Maximum Torque and Power Increase
* CARB EO Approved
1990-01 LS/RS(B18A-B) Part# 307-05-0280 (shown below) or
1994-01 GSR(B18C1) Part# 307-05-0270: $255 Shipped! NOVEMBER SALE!!!!**
Pro Series B-Series DOHC VTEC Throttle Bodies: Shipped!
• High Flowing Large Bore Capable Of Supporting 1000 HP
• Gains As High As 50+ HP On Forced Induction Applications
• Durable and Corrosion Resistant Hard Anodized Finish
• Uses Factory Throttle Cable
• CNC Forged AL6061-T6 Billet Aluminum
• Sealed Bearings For Smooth Operation
• MAP Sensor Relocated To Bottom side For Cleaner Look
• Eliminates Factory Waterlines For Cooler Operation
Available in 60, 66, 68, 70mm: $275 Shipped! SALE!!!!!!**
D - SERIES INTAKE MANIFOLDS BACK INSTOCK !
_ D15B7
_ D16A-Z
$219 shipped SALE' SALE!! IN STOCK ! ****
Combo: Intake Manifold and Throttle Body: $515 Shipped! SALE!!!**
Lower Control Arms:
# NEW! Clear Anodized finish (silver)
# CAE is used to analyze the strength and performance
# High-Quality CNC Machining
# Adjustable Sway Bar Mounting Holes
# Over 25% Lighter than Stock
# Polyurethane Bushings that Act as Bearings
# Forged AL-2024 I-Beam Design for Maximum Strength and Resistance to Twisting and Bending
88-95 Civic, 90-01 Integra Part# 542-05-0110: $189 Shipped! SALE!! ****
Silver Anodized:
Gold finish "Orange":
Rear Camber Kit:
# High-strength Forged Ends
# CNC Machined AL7075
# Hard Anodized Finish
1988-00 Civic CRX, Del Sol(ALL); 1990-01 Integra (ALL) Part# 516-05-0500: $160 Shipped! SALE!!!!!!**
Front Camber Kit:
# The Tuner Series features Skunk 2 industry standard one-piece forged ball joint that they pioneered the use of back in 2000.
# The new "square" washer plates tie the two bolts together to improve clamping and prevent distortion of the bolt slots.
Integra 94-01/Civic/Del Sol 92-95:
Tuner Series Front Camber Kit - $175 Shipped! SALE!!**
Pro Series Front Camber Kit - $195 Shipped! SALE!!
Pro Series +/- 4 Front Camber Kit - $225 Shipped! SALE **SALE !!!
Combo Front and Rear:
Pro-S Coilovers:
# Dual Tube Design
-miles@tunerzimage.com
AIM: TunerzImagemiles
email/paypal: miles@tunerzimage.com
ph: 909-628-1707 or toll free 1-877-488-6379 ASK FOR MILES!
Modified by tunerzimage at 1:38 PM 11/19/2007
Modified by tunerzimage at 1:40 PM 11/19/2007
Modified by tunerzimage at 12:38 PM 11/28/2007
Modified by tunerzimage at 4:52 PM 12/3/2007
Modified by tunerzimage at 12:36 PM 12/6/2007
Modified by tunerzimage at 12:40 PM 12/6/2007
Modified by tunerzimage at 12:43 PM 12/6/2007
Old Aug 28, 2007 | 09:29 AM
Banned
Default Re: Skunk2 blowout sale!!!! cheap !! ready to ship !! (tunerzimage)
Skunk2 short shifters ! on sale!! $90 shipped!!! XMAS price!!!!
Full skunk2 sport with coilovers!
call for pricing in stock ready to ship!!!
Skunk2 PRO SERIES ENGINE TUNING
Skunk2 CAMSHAFTS!
Skunk2 Pro-Series professional line of racing cams are designed to optimize mid-range and top-end HP and TQ. VTEC crossover is seamless allowing for the broadest possible powerband. No other line of racing cams can even come close to the performance of the Pro-Series line.
• B-Series Pro DOHC VTEC
• H-Series Pro DOHC VTEC
Tuner Series
Skunk2 Tuner Series camshafts retain factory idle quality and low speed emissions and also significantly increase HP and TQ. Many of the Skunk2 Tuner Series camshafts also feature Fast Ramp and Amax Technology which allow the engine to build more torque at lower rpm's.
• B-Series DOHC VTEC
• H-Series DOHC VTEC
• K20A2 DOHC VTEC
• K20A3 DOHC VTEC
• S2000 DOHC VTEC
• D-Series SOHC VTEC
• Mitsubishi 4G63BT
CAMSHAFTS STARTING $400 shipped!!
PLEASE CALL OR PM FOR MORE INFO!!!
SKUNK2 VALVETRAIN! COMBO!! *** NOVEMBER SALE!
Valves -
Though many aftermarket valves look similar, Skunk2 forged valves feature specifically designed valve head profiles to optimize airflow when used with stock or performance valve jobs.
Valve Springs
Skunk2 Racing valve springs have been developed as a result of our experiences in drag racing and touring car racing. Tuner Series springs are made from super clean chrome silicone wire milled in Japan.
Skunk2 Pro-Series
Valve springs are simply the best valve springs in the sport compact market. Pro-Series valve springs are designed to handle the demands of extreme lift camshafts running at the prolonged high rpms of professional championship level racing.
Skunk2 retainers are designed to significantly reduce overall valvetrain mass and are machined to extremely close tolerances in order to ensure properly installed spring heights and pressures.
In order to maximize horsepower, it is critical that camshafts are set at the proper position relative to crankshaft position. Pro-Series cam gears feature a super lightweight design and are CNC machined from 7075-T6 billet aluminum.
• Pro Series Cam Gears
Tuner Series
Skunk2 cam gears allow engine tuners to optimize horsepower and torque by adjusting camshaft timing. All Tuner Series adjustable cam gears are CNC Machined from 6061-T6 billet aluminum.
• Tuner Series Cam Gears
SUSPENSION
Skunk2 Strut tower bars!
Rear Lower Tie Bars
PM FOR PRICING!!
Modified by tunerzimage at 3:20 PM 11/1/2007
Modified by tunerzimage at 3:25 PM 11/1/2007
Modified by tunerzimage at 4:53 PM 12/3/2007
Modified by tunerzimage at 12:34 PM 12/6/2007
Old Aug 28, 2007 | 11:45 AM
Banned
Old Aug 29, 2007 | 10:59 AM
Banned
Old Sep 6, 2007 | 12:19 PM
Banned
Old Sep 11, 2007 | 08:32 AM
Banned
Old Sep 12, 2007 | 10:57 AM
Banned
Old Sep 18, 2007 | 11:34 AM
Banned
Old Sep 25, 2007 | 04:29 PM
Banned
Old Sep 26, 2007 | 01:53 PM
Banned
Old Oct 2, 2007 | 05:46 PM
Banned
Old Oct 4, 2007 | 10:52 AM
Banned
Old Oct 5, 2007 | 12:08 PM
Banned
Old Oct 5, 2007 | 12:09 PM
Banned
Old Oct 8, 2007 | 12:02 PM
Banned
Old Oct 10, 2007 | 01:37 PM
Banned
Old Oct 11, 2007 | 12:24 PM
Banned
Old Oct 15, 2007 | 12:08 PM
Banned
Old Oct 17, 2007 | 12:17 PM
Banned
Old Oct 18, 2007 | 04:11 PM
Banned
TTTTTT
Old Oct 23, 2007 | 10:33 AM
Banned
Old Oct 23, 2007 | 10:38 AM
Banned
Old Oct 24, 2007 | 11:44 AM
Banned
Old Oct 29, 2007 | 12:39 PM
Banned
Old Oct 29, 2007 | 12:59 PM
Sanda1s's Avatar
