99 Prelude help...
Old Aug 27, 2007 | 04:07 PM
GoCarInteg's Avatar
Default 99 Prelude help...
My girls car threw a couple codes... misfire in cylinders 1-4 and something about DTC (scanner said to check service manual). At first, thought it might be fouled plugs but didn't work. Heard something about a coil that might need to be replaced on preludes every so often. Anyone know?
P.S. Does anyone have a downloadable service manual that they can send me?
Old Aug 27, 2007 | 04:17 PM
vteclude07's Avatar
Default Re: 99 Prelude help... (GoCarInteg)
if its stick.. did she ever drop it into lower gear at high mph? if so check the timing belt and crank sensor. i had the same problem in my car, but first of all do a compression test at a local service. bent valves might be the reason the engine is misfiring
Old Aug 27, 2007 | 04:20 PM
GoCarInteg's Avatar
Default Re: 99 Prelude help... (vteclude07)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vteclude07 &raquo;</TD></TR><TR><TD CLASS="quote">if its stick.. did she ever drop it into lower gear at high mph? if so check the timing belt and crank sensor. i had the same problem in my car, but first of all do a compression test at a local service. bent valves might be the reason the engine is misfiring</TD></TR></TABLE>
She doesn't really drive hard or anything. Before it started with a misfire in 1 and 3 but now her CEL started blinking and it idles a little rough. Hopefully it won't be too expensive if it is.
Old Aug 27, 2007 | 04:24 PM
vteclude07's Avatar
thats exactly the problem that i had. turns out it was 4 bent valves on the intake side. like i wrote earlier, do a leak down compression test, its not that much
Old Aug 27, 2007 | 04:25 PM
GoCarInteg's Avatar
just out of curiousity, how much did it cost to fix?
Old Aug 27, 2007 | 07:44 PM
vteclude07's Avatar
Lol I didnt even do anything to it, its still sitting in the garage. I swapped a h22 in it
Old Aug 28, 2007 | 08:35 PM
GoCarInteg's Avatar
any chance it would be a distributor?
Old Aug 29, 2007 | 12:02 PM
vteclude07's Avatar
check the wires, plugs, distributor and the rotor
theres always a chance one of the plugs cracked...
Old Aug 29, 2007 | 01:25 PM
bluedlude's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GoCarInteg &raquo;</TD></TR><TR><TD CLASS="quote">any chance it would be a distributor? </TD></TR></TABLE>
yes, VERY good chance. switch it out with another lude distributor if you have a friend with one.
Old Aug 29, 2007 | 09:00 PM
GoCarInteg's Avatar
Default Re: 99 Prelude help... (bluedlude)
well the plugs are new but never knew that preludes needed "platinum laser" or "uridium" plugs. Gonna try the wires and hopefully everything works...
has anyone ever had a crank sensor go bad? if so, how does the car act when it does..
Old Aug 30, 2007 | 06:09 AM
bluedlude's Avatar
they dont need that type of spark plug, its just recommended. plugs and wires are usually just the easy quick thing to check. its likely the dist. or your crank position sensor. The crank position sensor relays where the crank is in degrees of rotation, while the cam angle sensor picks up when cyl no.1 is at TDC. if these two arent communicating with the ECU correctly, you get misfiring.
Old Sep 2, 2007 | 03:19 AM
GoCarInteg's Avatar
Okay so the "mechanic" told me that he couldn't figure out the problem and I'd have to bring it to Honda. He said that for some reason, the #1 injector is fouling. He can't figure it out and said it might be electrical. Then again, I talked to my buddy that used to be a tech @ honda and he said that the "ignition coil" or "coil pack" might have gone bad, and it's not very likely that an injector can go bad... I dunno. Gonna wait till tuesday I guess.
BTW, the mechanic still charged me for the new plugs/wires that he put in.
Old Sep 3, 2007 | 06:21 AM
bluedlude's Avatar
if the mech told you it was an injector, he should have switched that injector with one of the ones that works. and if the misfire follows the bad injector you switched, then its bad. really though, you NEED to get a manual and then you can troubleshoot it yourself the SAME way honda will do it.
keefe
Jun 15, 2008 12:32 PM
casmello
Jan 3, 2006 06:52 PM
kobeRy_si
Jun 6, 2005 03:59 AM
dimes_prelude
May 18, 2005 03:42 PM
gridelock
Mar 21, 2005 01:22 AM
