which tie rod do I need??
I'm doing a rear disc conversion on my ek. Not sure if I'm doing it with a teg rear or an si rear. Either way, fo I get a rear lower tie bar for whichever conversion I use or an ek?
Modified by rdeezy78 at 7:47 PM 8/27/2007
The tie bars you use for whatever car you own (although i believe 88-00 are all the same for the generic ones). If your talking about control arms then use the ones that are on the car already.
lower tie bar? the one for the subframe you have, which is an ek; the subframe span won't change just because you are changing LCA/trailing arms...
lowbOOsted
Jan 21, 2006 02:49 PM
