which tie rod do I need??
which lower tie bar do I need??
I'm doing a rear disc conversion on my ek. Not sure if I'm doing it with a teg rear or an si rear. Either way, fo I get a rear lower tie bar for whichever conversion I use or an ek?
Modified by rdeezy78 at 7:47 PM 8/27/2007
Re: which lower tie bar do I need?? (rdeezy78)
The tie bars you use for whatever car you own (although i believe 88-00 are all the same for the generic ones). If your talking about control arms then use the ones that are on the car already.
MiG-21 superfan
lower tie bar? the one for the subframe you have, which is an ek; the subframe span won't change just because you are changing LCA/trailing arms...
