B16A3 volumetric efficiency????????????????
Old Jun 14, 2002 | 05:18 AM
DigitalFusion's Avatar
Default B16A3 volumetric efficiency????????????????
been up all night trying to find it!!! anyone, anyone at all know what the stock VE of this motor is? the peak VE would be fine, but a map would kick ***!
Old Jun 14, 2002 | 05:34 AM
Default Re: B16A3 volumetric efficiency???????????????? (CustomCockpits)
i even called a few dealerships, they treated me like a jackass and didnt even understand what i was asking
Old Jun 14, 2002 | 09:18 AM
CHEETAH's Avatar
you're asking a much simplified question, I will give a simplified answer.
a stock b16a motor with Type R cams has about 89%VE. Don;t know how much it changes with stock b16a camshafts, figure 2-3% less. This is with no adjustable cam sprockets just stock gears set to manufacturers spec and with manufactures valvelash. It also had an air filter on the car wiht stock air hose, that will add 1-2% roughly, so figure a stock would be int he 85% range.
Greg
Old Jun 14, 2002 | 09:26 AM
2point6's Avatar
Default Re: B16A3 volumetric efficiency???????????????? (CHEETAH)
Greg
I am curious where you find your info on VE?
Old Jun 14, 2002 | 09:01 PM
Mista Bone's Avatar
D Tranny Guru
at what rpm's?
Easy to get a D series at 98-102% VE, just ask AEM.
That nice power spike, VE is near/above 100% VE thanks to ram effect.
Old Jul 3, 2002 | 09:33 PM
Greg
how can that be so low? the Prelude motors are 108%!?!
Old Jul 4, 2002 | 10:02 AM
Lsos's Avatar
I think the torque curve of the engine looks identical to its VE curve (Your engine has highest VE at its torque peak....~7000rpm?)
I thought the b16a's had closer to 95% VE...but it's only what I thought, no hard evidence to support it.
Old Jul 4, 2002 | 10:57 AM
Urban Business
Guest
Posts: n/a
Default Re: B16A3 volumetric efficiency???????????????? (Lsos)
flow bench it
Old Jul 4, 2002 | 12:45 PM
Default Re: B16A3 volumetric efficiency???????????????? (TorteX)
I could flow bench it, but I was hoping someone already knew... I am trying to map otu compressor flow charts, and it kinda sux just guestimating
DC5ftmfw
10
May 23, 2007 12:33 PM
sleeperb16a
Feb 17, 2005 09:42 AM
EGinNY
Feb 19, 2004 12:02 PM
onefastcx
Jan 13, 2003 10:25 AM
