whats a good "bolt on" turbo kit
Old Aug 26, 2007 | 06:36 PM
sinister357's Avatar
Default whats a good "bolt on" turbo kit
the thought has crossed my mind about turbo charging my 96 gs-r. where to start? any decent "bolt on" kits available that will allow a/c? any reading book or site you recommend in learning about turbos?
Old Aug 26, 2007 | 06:37 PM
Garage 808 Hatch's Avatar
i dont know about a/c compatibility, but peak boost makes some bad *** ****
Old Aug 26, 2007 | 06:38 PM
slooogsr's Avatar
Check the sponsors forum, Peakboost, Full-Race, and AFI should have something to suit you........
Old Aug 27, 2007 | 02:41 AM
TURBODC4TEG's Avatar
Default Re: (slooogsr)
why not rev hard
Old Aug 27, 2007 | 03:41 AM
Adriano's Avatar
Default Re: (TURBODC4TEG)
I used to have a rev-hard kit and loved it. I went 10.9 on it and it was a/c comparable (i didn't have a/c though)
Adriano
Old Aug 27, 2007 | 05:32 AM
Schister66's Avatar
Man U FTW
If you take some time and look around the Sponsor's Classifieds, you should be able to find a good AC compatible setup. Like a few others have said, check into the Peakboost setups because they seem to be a good kit for the money.
I used to run a SPoolin log manifold which was AC, PS and full radiator compatible. It was a good setup, but i didnt get the 3" dp....
Old Aug 27, 2007 | 11:24 AM
RIP V8s's Avatar
Default Re: (Schister66)
also depends if you plan to build in the future. id go with a afi street kit with like a 28rs if you plan on keeping it low boost. should be good for close to 300 as long as you have a good tuner to use.
Old Aug 27, 2007 | 11:30 AM
SHPrelude00's Avatar
Default Re: (RIP V8s)
turbonetics makes good kits... and their new kits are a lil more but come with the right electronics and all the right things work without engine lights... and in most cases are pretty well said 'bolt on'
Old Aug 27, 2007 | 03:37 PM
kcjohnnyboy's Avatar
Default Re: whats a good "bolt on" turbo kit (sinister357)
greddy makes a good starter kit, which i purchased and i like it
daredeezy619
Feb 7, 2008 11:45 AM
HondaTeKnology
Jan 5, 2008 04:47 PM
DC-2uned
May 6, 2007 07:29 PM
JoeDaSoto
Sep 22, 2006 06:22 PM
Phatch99
Mar 22, 2005 06:46 AM
