ATI super damper?
Old Aug 26, 2007 | 04:08 PM
integraboosted's Avatar
Default ATI super damper?
I know its kinda like a noob question, but do I need a special tool to install one of these dampers its going on a b seires motor. Or it goes in like a stock damper thanks.
Old Aug 27, 2007 | 03:42 AM
DaveF's Avatar
Default Re: ATI super damper? (integraboosted)
the ati damper is a very tight fit. i have never used a press or anything to install one, you should be able to get it on with the oem bolt, just be sure its going on smooth, otherwise you will end up galling the crank snout and the hub of the damper, and that is no bueno.
Old Aug 27, 2007 | 07:53 AM
Default Re: ATI super damper? (DaveF)
thanks.
Old Aug 27, 2007 | 11:12 AM
ninesecrx's Avatar
You will only need a puller to get it off...otherwise like what was said above.
Old Aug 27, 2007 | 12:09 PM
turbotypeR@SPEC's Avatar
25 Year Member
Default Re: ATI super damper? (ninesecrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ninesecrx &raquo;</TD></TR><TR><TD CLASS="quote">You will only need a puller to get it off...otherwise like what was said above.</TD></TR></TABLE>
what he said
Old Aug 28, 2007 | 11:09 PM
714phil's Avatar
Default Re: ATI super damper? (turbotypeR@SPEC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbotypeR@SPEC &raquo;</TD></TR><TR><TD CLASS="quote">
what he said</TD></TR></TABLE>
yeah what he said
Old Aug 29, 2007 | 12:14 AM
ninesecrx's Avatar
Default Re: ATI super damper? (714phil)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 714phil &raquo;</TD></TR><TR><TD CLASS="quote">
yeah what he said</TD></TR></TABLE>
yup, he said it
Old Sep 10, 2007 | 08:00 PM
I got mines put on it was stiff as heck but, I'tll work I hope i dont break an oil pump at the dyno.
Old Sep 13, 2007 | 02:33 PM
h22 civic's Avatar
yup, he said it</TD></TR></TABLE>
he sure did say it
Old Sep 13, 2007 | 03:57 PM
Team Evol Tyrone's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by integraboosted &raquo;</TD></TR><TR><TD CLASS="quote">I know its kinda like a noob question, but do I need a special tool to install one of these dampers its going on a b seires motor. Or it goes in like a stock damper thanks.</TD></TR></TABLE>
All that they said but if I was you I would take a dab of lubricant and rub it on the crank snout and ease it on.
Old Sep 13, 2007 | 04:11 PM
ninesecrx's Avatar
Default Re: ATI super damper? (freakyty2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by freakyty2 &raquo;</TD></TR><TR><TD CLASS="quote">
All that they said but if I was you I would take a dab of lubricant and rub it on the crank snout and ease it on. </TD></TR></TABLE>
You can't ease it on, they are a press fit. It has to be that way in order to take vibrations out properly.
Old Sep 13, 2007 | 04:13 PM
tony1's Avatar
I always use some anti seize between the crank and pulley, just so it doesn't get stuck. Says to do so in the instructions from ATI
Old Sep 13, 2007 | 04:24 PM
HR-1320's Avatar
Default Re: ATI super damper? (tony1)
Did you get one with an aluminum hub or steel.
Old Sep 13, 2007 | 04:29 PM
tony1's Avatar
Default Re: ATI super damper? (HR-1320)
Steel
Old Sep 13, 2007 | 05:49 PM
Turbo-charged's Avatar
i use anti seize too........use the steel hubs, stay away from the aluminum ones. i have seen a few issues with those...never a problem with the steel.
ive used both the fluiddamper and ati on my car.
Old Sep 13, 2007 | 06:11 PM
Boostfed's Avatar
New User
Default Re: ATI super damper? (Turbo-charged)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turbo-charged &raquo;</TD></TR><TR><TD CLASS="quote">i use anti seize too........use the steel hubs, stay away from the aluminum ones. i have seen a few issues with those...never a problem with the steel.
ive used both the fluiddamper and ati on my car.</TD></TR></TABLE>
Yep Fluidampr aluminum rounded out on me, I have a steel ATI now
Old Sep 13, 2007 | 09:27 PM
You can't ease it on, they are a press fit. It has to be that way in order to take vibrations out properly.</TD></TR></TABLE>
I put lube and got in on a little and took my airgun and slowly eased it on with air sorry I didn't specify it. Small burst with the gun until it was flush and then torqued.
Old Sep 13, 2007 | 11:07 PM
ninesecrx's Avatar
I put lube and got in on a little and took my airgun and slowly eased it on with air sorry I didn't specify it. Small burst with the gun until it was flush and then torqued. </TD></TR></TABLE>
Gotcha, yeah...it does not take much, but they will not go on by hand. The bolt works great to pull them on.
Old Sep 14, 2007 | 11:16 AM
Mista Bone's Avatar
D Tranny Guru
Mike, you happen to know the crank snout diameter for a B series?
I've got a spare crank pulley here, SWORE it was off a SOHC, but it has a 28mm bore.
LS maybe????
Thanks.
Old Sep 14, 2007 | 11:23 AM
ninesecrx's Avatar
Default Re: (Mista Bone)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mista Bone &raquo;</TD></TR><TR><TD CLASS="quote">Mike, you happen to know the crank snout diameter for a B series?
LS maybe????
Thanks.</TD></TR></TABLE>
28mm would be a B series pulley. I think single cams are 24mm.
Old Sep 14, 2007 | 11:26 AM
Mista Bone's Avatar
D Tranny Guru
early SOHC (88) were 22mm, rest 24mm.
great, 1 cam 4 life and how did I get this part?
LOL, Thanks Mike.
BTW: ATI gonna make a D Damper?
Old Sep 14, 2007 | 11:38 AM
ExospeedAMcrx's Avatar
BTW: ATI gonna make a D Damper?</TD></TR></TABLE>
they can make it if you need to. We've had custom Pulleys made in the past.
Old Sep 14, 2007 | 12:36 PM
ninesecrx's Avatar
Default Re: (ExospeedAMcrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ExospeedAMcrx &raquo;</TD></TR><TR><TD CLASS="quote">
they can make it if you need to. We've had custom Pulleys made in the past.</TD></TR></TABLE>
Custom ones are pretty pricey though, but they can make anything there...pretty neat company!
Old Sep 14, 2007 | 12:39 PM
Default Re: (ninesecrx)
Custom ones are pretty pricey though, but they can make anything there...pretty neat company!</TD></TR></TABLE>
yup they are. but if someone really wanted it, be prepared to pay the price.
Old Sep 14, 2007 | 07:46 PM
Mista Bone's Avatar
D Tranny Guru
Good to see you around Wil!!!!!
You likely saw the Mercedes SC I'm adapting to where the AC used to be. Well the stock pulley on the crank wasn't big enough, could only spin the SC to about 11,000 rpm with engine @ 7500 rpms. Need 2:1 drive ratio.
Then while going thru an autoparts online auction, I cam across a universal AC mount, comes with 6 rib tensioner, just the the SC clutch/pulley......so I'd need a larger than stock 6 rib pulley
upper AC tensioner will no longer be needed
yes, that lightweight pulley is just for mock-up
