91 accord runs rough main relay question
Old Aug 26, 2007 | 01:17 PM
stegmo2's Avatar
Default 91 accord runs rough main relay question
changed plugs rotor and cap. main relay is intermittent on bench test, will that cause the engine to run rough. when i had a fuel pressure gauge hooked up sometimes it would not show pressure when the key was turned on then after on/off cycles it would come on. driving the pressure was good or the gauge said it was? but i noticed the ignitor is also controled by the main relay. i jumered the 5 and 7 and the fuel output in a can was very strong. any ideas as to what to check next?
K00lGuy
Jan 14, 2016 10:49 AM
jong93
Oct 3, 2012 10:41 PM
SeanaK
May 3, 2012 07:04 PM
kiba
Nov 5, 2008 10:23 PM
Hondasaurs
Apr 11, 2003 02:25 PM
