gsr or itr throttle cable
Old Aug 26, 2007 | 12:37 PM
B18cFreak's Avatar
Default gsr or itr throttle cable
i have a eg and im putting in a jdm b18cR. am i supposed to use a type r throttle cable or a gsr cable?
Old Aug 26, 2007 | 02:04 PM
hybridmath's Avatar
Default Re: gsr or itr throttle cable (B18cFreak)
if your refering to the b18c5 type r engine you want to use the type r throttle cable if you have a b18c1 use the gsr cable
Old Aug 26, 2007 | 02:31 PM
Luserkid's Avatar
Default Re: gsr or itr throttle cable (hybridmath)
Just use the stock civic throttle cable.
Old Aug 26, 2007 | 02:36 PM
B18cFreak's Avatar
no. i have the jdm b18c from a type R. or is the usdm c5 the same as the j spec R? will the cable from the d15 work that is already on the car? i heard you cant use them.
Old Aug 26, 2007 | 03:39 PM
95sloweg's Avatar
You cant use the stock throtttle cable due to issues with the position of the throttle cable bracket. You should use the type r.
Old Aug 26, 2007 | 05:47 PM
egsleepercivic's Avatar
type r
rick_rabies
May 5, 2009 07:55 AM
SpoonEk253
May 27, 2006 06:20 PM
cjames235
Jul 22, 2004 10:23 AM
euclid
May 4, 2003 05:21 PM
B18C2_sedan
Nov 26, 2002 12:40 PM
