Power Estimate for newly built GSR
Old Aug 26, 2007 | 06:28 AM
GSE980's Avatar
Default Power Estimate for newly built GSR
Can anyobne give me a estimate of what a GSR makes as far as Hp or torque given the following specs.
Its a .5 bored out 8.5:1 GSR
the only mods it has is a walbro bigger fuel rail chipped ECU
bored out head and IHE
Im going to get it tuned when I come home from the desert, Im think Im going to take it to Green Light automotive in S.D. any comments on that??
I just want to have a ballpark figure so I know they aren't bullshitting me
thanks guyz
Old Aug 26, 2007 | 06:59 AM
cartune network's Avatar
Default Re: Power Estimate for newly built GSR (GSE980)
i hope your going to turbo that thing cause with that low of a compression ratio ur barely making as much hp as a b16. if u dont plan on boosting it than i wouldnt buy it cause tha comp ratio is way low.
Old Aug 26, 2007 | 07:02 AM
del sol b18c's Avatar
do you have a tubo or something. Why the hell does it have 8.5:1 compression, you didn't say it had a turbo so i'm assuming your that your just so stupid as to run 8.5:1 all motor. You probably won't reach 150 horse with that.
Old Aug 26, 2007 | 09:15 AM
Default Re: Power Estimate for newly built GSR (cartune network)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by del sol b18c &raquo;</TD></TR><TR><TD CLASS="quote">do you have a tubo or something. Why the hell does it have 8.5:1 compression, you didn't say it had a turbo so i'm assuming your that your just so stupid as to run 8.5:1 all motor. You probably won't reach 150 horse with that.</TD></TR></TABLE>
not even on a cold day.
Old Aug 26, 2007 | 01:01 PM
GSE980's Avatar
Default Re: Power Estimate for newly built GSR (del sol b18c)
NO TURBO because its a NEW motor.
Should I just assume that your stupid, go ahead, and explain why there is not a turbo on the engine yet.
I asked what kind of Hp it would make....in my list of upgrades did it say turbo ...NO does it look like my car is setup to run turbo yet NO I just asked how much the engine would make.
&lt;150.......roger
Just to get you off and tickle your fancy I got a pro street setup off of fullrace and we are fabricating different parts for the exhaust out of the exhaust we use on our hornets and prowlers.
Old Aug 26, 2007 | 01:05 PM
GSE980's Avatar
&lt;150.......roger
Egfreak
34
Mar 17, 2011 10:29 AM
Egfreak
Mar 15, 2011 08:01 PM
playalistic2
Dec 29, 2005 05:15 AM
cbabyby
Mar 19, 2005 03:49 AM
BlackTEG99
Dec 22, 2004 10:24 PM
