Broken bolt in block....What to do?!?
Old Aug 26, 2007 | 03:43 AM
xanonymousx's Avatar
Default Broken bolt in block....What to do?!?
I was installing my hasport ac bracket for my b18 crx. I snugged all the bolts down for the bracket to the block. When I went to fully tighten the last one it snapped off and there is maybe 1mm sticking out the block. Also, I took the other long bolt out and the last ~5 thread were filled with metal....like it peeled off metal from the block. What do you think caused this problem and how would I fix it. I know some people will say overtighten but I didn't put that much muscle into to it.
Old Aug 26, 2007 | 09:14 AM
BILLETGRIP's Avatar
Default Re: Broken bolt in block....What to do?!? (xanonymousx)
you probably used to long of a bolt and it bottomed out.
Old Aug 27, 2007 | 01:20 PM
SIred91's Avatar
Rainman
Default Re: Broken bolt in block....What to do?!? (BILLETGRIP)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BILLETGRIP &raquo;</TD></TR><TR><TD CLASS="quote">you probably used to long of a bolt and it bottomed out.</TD></TR></TABLE>
x2....or the metal is just old and fatigued and the threads pulled out.
But most likely, unless you used the stock bolt leanghts, you bottomed out and broke and stripped them....
Time to learn to use a tap and a heli coil kit.
Old Aug 27, 2007 | 02:47 PM
Default Re: Broken bolt in block....What to do?!? (SIred91)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SIred91 &raquo;</TD></TR><TR><TD CLASS="quote">x2....or the metal is just old and fatigued and the threads pulled out.
Time to learn to use a tap and a heli coil kit.</TD></TR></TABLE>
Is the engine going to have to be pulled to do this?
Old Aug 27, 2007 | 02:59 PM
BILLETGRIP's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xanonymousx &raquo;</TD></TR><TR><TD CLASS="quote">
Is the engine going to have to be pulled to do this?</TD></TR></TABLE>
not if your good with a hand drill
Old Aug 28, 2007 | 12:46 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BILLETGRIP &raquo;</TD></TR><TR><TD CLASS="quote">not if your good with a hand drill</TD></TR></TABLE>
Seems like it would be a little hard to get it going in straight.
Old Aug 28, 2007 | 05:52 AM
jayturboef's Avatar
if i were you i would pull it you will save your self a headache
Old Aug 28, 2007 | 08:03 PM
BILLETGRIP's Avatar
Default Re: Broken bolt in block....What to do?!? (jayturboef)
Seems like it would be a little hard to get it going in straight.</TD></TR></TABLE>
use a 90 degree drill. it will pretty much follow the hole that is already there. its really not that big of a deal.
theidealone
Nov 27, 2010 07:45 PM
vtecx2
Feb 23, 2010 12:09 PM
garylythgoe
Aug 1, 2006 11:56 AM
civicEXtreme
Suspension & Brakes
Feb 22, 2006 02:36 PM
93preludes
Dec 4, 2003 01:58 PM
