timing belt situation. Belt won't stay centered on cam gears.
Old Aug 25, 2007 | 11:42 PM
realis9's Avatar
Default timing belt situation. Belt won't stay centered on cam gears.
My timing belt is not staying centered on both cam gear. whenever i push the belt in the center of the cam gear, the minute i start the car i see the belt drift over to the outer edge of the cam gear ( the very out edge). It doesn't slip off but it stays right at the other edge. What could be wrong?
Old Aug 25, 2007 | 11:47 PM
jdmracer12's Avatar
Default Re: timing belt situation. Belt won't stay centered on cam gears. (realis9)
possibly the bearings in your waterpump or your belt tensionor are bad. this will cause the pulleys to become cocked and not let the belt ride in the center. just my guess.
Old Aug 26, 2007 | 12:05 AM
realis9's Avatar
Default Re: timing belt situation. Belt won't stay centered on cam gears. (jdmracer12)
everything is brand new. Water pump timing belt oil pump and tensioner.
LSTurbo23
Jan 31, 2011 01:38 PM
realis9
Aug 26, 2007 12:52 AM
NoVALude
Jul 19, 2006 11:53 AM
iwouldHITit
Apr 20, 2003 05:20 PM
