are drilled and slotted rotors worth it?
Old Jun 13, 2002 | 10:37 PM
crxzc's Avatar
Default are drilled and slotted rotors worth it?
i found some of these on groupbuycenter and am wondering if they are worth it. would i notice a lot better braking if i got a set of them.
Old Jun 14, 2002 | 02:44 AM
Viorent GRIP!'s Avatar
Default Re: are drilled and slotted rotors worth it? (crxzc)
Nope, unless you're gonna go from 140 to 80 to hit a turn. A good set of pads is what you want. Otherwise the rotors are just there to look pretty
Old Jun 14, 2002 | 03:38 AM
thecaptain's Avatar
No, drilled rotors certainly aren't worth the extra money. They easily stress crack. Sloted rotors, perhaps, depending on what you are using them for. On the street or for autox, no. For the track, yes there are benefits.
Ron Spencer
Old Jun 14, 2002 | 08:36 AM
crxzc's Avatar
Default Re: are drilled and slotted rotors worth it? (thecaptain)
so is it better if i just go with better pads? i really want better brakes!!! what are some brands that make pads that you would recommend.
Old Jun 14, 2002 | 08:46 AM
Kasper.'s Avatar
Get dual piston calipers, better pads, and steel braided brake lines, that will tighten up your braking alot more and feel alot firmer.
Old Jun 14, 2002 | 09:13 AM
E-lude78's Avatar
are slotted and cross drilled rotors machinable?
em1gangsta
Suspension & Brakes
Nov 16, 2008 02:37 PM
mingus
Honda S2000
22
Feb 20, 2008 12:23 PM
standbackimapro
Sep 21, 2007 11:27 AM
H2290
10
Jul 28, 2006 01:56 PM
triple
May 22, 2006 10:49 AM
