ASR Brace & CTR Swaybar Installed
Old Aug 25, 2007 | 01:56 PM
Spoon_Si-R's Avatar
Default ASR Brace & CTR Swaybar Installed
Hey guys,
I just finished installing the brace and swaybar myself today and I dont think the endlinks look right? Can I have some opinions/suggestions?
View from the back
Old Aug 25, 2007 | 02:10 PM
pdiggitydogg's Avatar
No, your endlink needs to be seated - it will slide around too much otherwise.
Loosen the nuts, slide the bolt all the way though the link and adjust the nuts accordingly.
You will want to get some nylon washers as spacers between parts, so it quiets down a little (unless you dont mind all the knocking sounds from the rear)
Old Aug 25, 2007 | 02:30 PM
Spoon_Si-R's Avatar
Yeah i just did that, Its a tad bit more vertical but could be more...Maybe I need aftermarket control arms?
Old Aug 25, 2007 | 02:35 PM
chinoty's Avatar
Default Re: (Spoon_Si-R)
If those are BLOX endlinks, good luck.. I was having so much problems with them when I install my ITR sway bar. I also have BLOX LCA and still it didnt sit rite. I used so many washers and still didnt look rite. Actually look just like what you had on here. So I end up using my OEM endlinks.
Old Aug 25, 2007 | 02:40 PM
BlueIntegraBoy's Avatar
Default Re: ASR Brace & CTR Swaybar Installed (Spoon_Si-R)
See the blue mark on the sway? It's supposed to be under the bushing. Shift over your bar.
Old Aug 25, 2007 | 03:02 PM
Spoon_Si-R's Avatar
I'm using Function 7 endlinks which I heard aren't that great either. I tried to push it over but it won't move, I'm too lazy to unbolt everything again.
Old Aug 25, 2007 | 03:03 PM
Spoon_Si-R's Avatar
Is it safe to drive for a couple of days like that?
Old Aug 25, 2007 | 03:08 PM
highrev1987's Avatar
why not do it like this?
Modified by highrev1987 at 7:20 PM 8/25/2007
Old Aug 25, 2007 | 04:33 PM
Spoon_Si-R's Avatar
lol nice....that makes perfect sense, I'll try that tomorrow....I drove the car around and there is no noise or clanking.
Old Aug 25, 2007 | 04:48 PM
zoso's Avatar
i have the same problem, how much are oem endlinks...
ZombiePharoh
Suspension & Brakes
Feb 23, 2014 08:36 PM
gfunkmos37
Suspension & Brakes
Nov 29, 2007 04:03 AM
Spoon_Si-R
Suspension & Brakes
16
Aug 28, 2007 01:08 PM
Mr. 1582
Jan 1, 2004 08:53 PM
seek167
Mar 11, 2003 03:48 AM
