ASR Brace & CTR Swaybar Installed
Hey guys,
I just finished installing the brace and swaybar myself today and I dont think the endlinks look right? Can I have some opinions/suggestions?
View from the back
View from the back
No, your endlink needs to be seated - it will slide around too much otherwise.
Loosen the nuts, slide the bolt all the way though the link and adjust the nuts accordingly.
You will want to get some nylon washers as spacers between parts, so it quiets down a little (unless you dont mind all the knocking sounds from the rear)
Re: (Spoon_Si-R)
If those are BLOX endlinks, good luck.. I was having so much problems with them when I install my ITR sway bar. I also have BLOX LCA and still it didnt sit rite. I used so many washers and still didnt look rite. Actually look just like what you had on here. So I end up using my OEM endlinks.
