code 20 on s300....elictric load detector????
Old Aug 25, 2007 | 12:15 PM
tegman23's Avatar
Default code 20 on s300....elictric load detector????
after a long build i started my car and its running pretty well for the first start up but its throwing code 20 ELD....what does this do im pretty sure its the electric load detector in the distributor...but what does this do...the car seems to be running fine....im taking the car to get tunned and just wanted to check to make sure this isnt mager.....thanks for the help.
if your need to know its a b16a fully built converted to obd1 running hondata s300.
Old Aug 25, 2007 | 12:25 PM
90dxhmt's Avatar
Default Re: code 20 on s300....elictric load detector???? (tegman23)
I would not worry about it.You should be able to turn it off in the management Im not sure with Hondata but you can with most others.Double check your alt fuse is good and that there is no wires bare anywhere but I have had that code come up with chipped ecus in the past and it was not a mechanical issue.It doesnt effect the running of the car just sets the light off.
Old Aug 25, 2007 | 12:45 PM
Flexmyrex's Avatar
ELD is in the main fuse box, it sends an input signal to the pcm, the pcm uses it as a reference to control the voltage reg. I would double check your obd1 conversion wiring, if not then you'll have to replace the fuse box as it is built in. Even though it is not a common problem I have had to replace a couple of them before.
Old Aug 25, 2007 | 12:52 PM
OLD_HATCH's Avatar
eld sensor is actually in the enginebay fusebox. it measures electric load so that the ecu can compensate by adjusting iacv to keep idle where its supposed to be at.
you should be able to turn it off somewhere in the software, but if not its not a big deal.
Old Aug 25, 2007 | 01:21 PM
Tchleung's Avatar
Perameters -> Misc -> Bullet in {Disable ELD}
Old Aug 25, 2007 | 01:39 PM
RACEPAK's Avatar
Default Re: (OLD_HATCH)
how many pepole you know run with a disabled eld?
Old Aug 25, 2007 | 02:12 PM
Tchleung's Avatar
Mine is diabled since I use the ELD as an input for my wideband.
Old Aug 25, 2007 | 02:23 PM
RACEPAK's Avatar
Default Re: (Tchleung)
oops i ment enabled....
what do you mean by wideband input?
Old Aug 25, 2007 | 03:53 PM
Tchleung's Avatar
So my ECU reads and logs wideband A/F as well as narrowband A/F
Old Aug 25, 2007 | 04:19 PM
Mr.Death's Avatar
I don't mean to threadjack but I have a code 20 as well and when my car gets to operating temp the idle is lumpy. Could this be cause of the ELD? I've been trying to get to the bottom of this for some time now.
Old Aug 25, 2007 | 05:08 PM
RACEPAK's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tchleung &raquo;</TD></TR><TR><TD CLASS="quote">So my ECU reads and logs wideband A/F as well as narrowband A/F</TD></TR></TABLE>
what managment?
Old Aug 25, 2007 | 07:25 PM
tegman23's Avatar
thanks for the info i guess that would explain why the car is idling at 1300-1400???
ps the car was already obd1..i just converted the motor...
Old Aug 25, 2007 | 09:29 PM
Turbogixxer's Avatar
Default Re: (tegman23)
What chassis is the car? 90-93 integra by chance?
Old Aug 25, 2007 | 09:56 PM
Tchleung's Avatar
Default Re: (RACEPAK)
Hondata S300, which is what the OP is talking about.
Old Aug 26, 2007 | 07:36 PM
tegman23's Avatar
ya its a 92 DA
Old Aug 26, 2007 | 08:51 PM
They do not have a ELD, disable it.
Old Aug 27, 2007 | 05:53 PM
tegman23's Avatar
o ok i just thought since i put a b16 in it made a diffrence thanks
Old Nov 27, 2008 | 01:51 PM
viskii420's Avatar
I got the same issue w. error code 20 but hondata doesn't point out anything about this issue.
If i use d10 as an wideband input [in my case plx m300], ELD should be disabled from Smanager?
Old Nov 27, 2008 | 07:19 PM
ladysman's Avatar
Just disable it in the Smanager software. It's under the MISC tab.
EG6_LS_BOOST
15
Jul 17, 2013 02:55 PM
wreckeddc4
Sep 3, 2012 01:46 PM
thegreasemonkey
May 10, 2011 03:58 AM
the.hamburglar
Jul 6, 2005 02:52 PM
JDM EJ1 95
10
Jul 11, 2004 12:51 PM
