blown tail light fuse
Old Aug 25, 2007 | 11:26 AM
nick1989's Avatar
Default blown tail light fuse
Have 1999 Honda Prelude. Tail lights not working. Checked for blown fuse. Found blown fuse and changed. Started vehicle and turned on lights. Tail light fuse blows every time .....any suggestions?
Old Aug 25, 2007 | 11:30 AM
nonvteclude's Avatar
Default Re: blown tail light fuse (nick1989)
you have a short somewhere, you are going to have to track through the wiring and see where it is. its also possible that a ground is loose somewhere for the tail lights
Old Aug 25, 2007 | 05:58 PM
98vtec's Avatar
moderator emeritus
are you replacing the fuse with the same amp?
Old Aug 26, 2007 | 05:42 AM
nick1989's Avatar
Default Re: blown tail light fuse (98vtec)
Yes. 15 amp
Old Aug 27, 2007 | 01:41 PM
310Integra's Avatar
Check the wiring on the tail lights. make sure everything is tight and not loose. and check and loose wires making sure they are not positive. If does not work try the next amp which is 20amp if you blow it then. Have someone that know how to fix that problem do it for you.
Riah Reynolds
Honda Civic (2001 - 2005)
Oct 22, 2016 07:07 PM
jdmEF8racer
Sep 2, 2011 09:48 PM
924doorEG
Aug 5, 2007 08:04 PM
Daniel98328
Feb 22, 2007 02:36 PM
jdmkid8383
Sep 11, 2006 06:03 AM
