RPM's fluctuate when accelerating
Old Aug 25, 2007 | 09:15 AM
aguilasrafa10's Avatar
Default RPM's fluctuate when accelerating
Hi, I have a 1994 Honda Civic Ex manual transmission with a V-TEC motor that has been giving me problems. Once the car has reached operating temperature (about 20-30 min), the rpm's fluctuate up and down when accelerating. This only happens when you accelerate making the car impossible to drive because it stalls.
Any help will be great.
Old Aug 25, 2007 | 09:16 AM
philosofy1's Avatar
Default Re: RPM's fluctuate when accelerating (aguilasrafa10)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by aguilasrafa10 &raquo;</TD></TR><TR><TD CLASS="quote">Hi, I have a 1994 Honda Civic Ex manual transmission with a V-TEC motor that has been giving me problems. Once the car has reached operating temperature (about 20-30 min), the rpm's fluctuate up and down when accelerating. This only happens when you accelerate making the car impossible to drive because it stalls.
Any help will be great. </TD></TR></TABLE>
your check engine light hasn't came on has it?
Old Aug 25, 2007 | 09:25 AM
Default Re: RPM's fluctuate when accelerating (philosofy1)
no, my check engine light hasn't come on
Old Aug 25, 2007 | 10:14 AM
you know what it can be?
Old Aug 25, 2007 | 10:16 AM
philosofy1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by aguilasrafa10 &raquo;</TD></TR><TR><TD CLASS="quote">you know what it can be?</TD></TR></TABLE>
try replacing the pcv valve. sometimes they get clogged and cause the motor to fluctuate.
also, when was the last time you did a tune up?
Old Aug 25, 2007 | 10:19 AM
where is the pcv valve located at? I just did a tune up but didn't change the wires though..
Old Aug 25, 2007 | 10:23 AM
philosofy1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by aguilasrafa10 &raquo;</TD></TR><TR><TD CLASS="quote">where is the pcv valve located at? I just did a tune up but didn't change the wires though..</TD></TR></TABLE>
eww...that can be the problem (if the wires are old enough). yeah, i just reread the post and noticed that you said it stalls as well.
go ahead and replace the wires and the pcv valve should be located on the intake manifold.
here this link as a sketch:
http://www.thehondapartsstore....ch=no
item number 6 is the valve. it is a cheap replacment, like $3.
Old Aug 25, 2007 | 10:34 AM
one more thing. the rpm's only fluctuate when you accelerate the car. in other words, if the car is just turned on, the idle is normal.
Old Aug 25, 2007 | 10:42 AM
philosofy1's Avatar
hmmm...check all the hoses around the I/M. look for any broken, crakced. or cut vaccum hoses. you might have a vaccuum leak.
Old Aug 25, 2007 | 10:53 AM
Sorry. I don't know anything about cars. what's the I/M?
z626specialk
Honda Civic (2006 - 2015)
May 15, 2006 07:04 PM
streetz_crazy
Sep 6, 2005 05:16 PM
torch1986
18
Dec 1, 2004 04:23 AM
liem43
Mar 11, 2004 12:41 AM
JDMs1eeper
May 15, 2003 09:59 PM
