b18 swap
Old Aug 25, 2007 | 08:21 AM
1xfastxhatch's Avatar
Default b18 swap
i have a 95 civic hatch cx and i bought a 92 integra ls witha b18a1 i have the motor pulled but before i star tearing into the civic i need to know what motor mounts, shift linkage, wiring harness/ ecu, and axels i should use any help would be great
Old Aug 25, 2007 | 06:30 PM
skellator_thoj's Avatar
Default Re: b18 swap (1xfastxhatch)
you need the integra rear mount bracket, driver side mount and pass front tranny mount with matching half shaft and axles, hydro trans, a obd1 pr4 ecu which you already have . The swap should be a easy bolt on affair and ready to run.
Old Aug 27, 2007 | 03:31 AM
well i have a cable trans so what do i need
Old Aug 29, 2007 | 10:44 AM
so it should just bolt right in with the cable trany with the cable to hydro conversion kit because ive gotten different answers about the mounts and axels so i want to be shure
Old Aug 31, 2007 | 02:53 PM
if your going to keep the cable trans, you need to buy a conversion kit from hasport which should include the tranny mounts and cable to hydro, you'll also need a odb1 b series driver side motor mount bracket i believe.
91civicsikid
Jun 13, 2008 05:14 AM
0ldsk00lef
Feb 4, 2008 05:36 AM
AJxr
Nov 20, 2006 10:53 AM
AudioXtremes
Jul 24, 2006 11:02 AM
import_racer_ky
Apr 10, 2004 01:26 AM
