New Idle Problem Now!
In my last few posts I had wrote about my car being stumbly and pretty much not being able to take off with the a/c on etc etc. All leads said I should try cleaning my IACV, So this morning I pulled it off, cleaned it real good and put everything back, Now my car drives great with the a/c on, But now I have the famous pulsing idle That just goes up and down, even after clearing the ecu and letting it warm up. So what does this mean, whats next on the list for my new car? lol
Thanks, got some more stuff to try tomorrow, I switched out to my friends ecu and all it changed was made the "hunting idle" faster, Im hoping I didnt f up the IACV cleaning it. Also how can you bleed the air out your coolant if the bleeder screw is gone? My coolant was low and I filled it earlier
I would look for vaccum leaks by getting some brake clean or something and spray it all around the iacv and if the rpms change at all you know there is a leak cause the brake clean made its way into combustion chamber and is trying to combust. just a thought.
It sounds like you need to bleed the coolant system.
Put the heater to hot but leave the fan off.
Remove the radiator cap. Start engine. Top off fluid level as needed. Wait until the cooling fan kicks on once. Turn engine off and re-install radiator cap.
"Ive got a spare IACV. Do you want it?"
How much?
"Ummmmmmmmmmm starting fluid loved by deisel owners and number one way to find piston rings in your oil on a gas motor. "
Well that small of a mist isnt going to hurt anything and it seemed like a btter idea then the previous suggestion of brake cleaner...
Ok I pulled the valve off again, and made sure it sealed this time. The car idles better and runs PERFECT with the a/c on now, But still hunts for idle with the a/c off. Im gonna try replacing the valve
tothewall
Oct 7, 2010 12:43 PM
byronl
Jun 14, 2006 08:26 PM
