crooked engine, tranny mount?
Old Aug 25, 2007 | 07:41 AM
blackfoot's Avatar
Default crooked engine, tranny mount?
alright , i have a 92 4 door lx, and i did a auto to manual conversion on this car..
now before i got this car i helped my friend put an engine in it, and it was sitting crooked..
do i need a special mount from the transmission to the body so the engine sits striaght??? i heard of these mounts hasport has to offer. but is that neccessairy and am i missing something.
Old Aug 25, 2007 | 07:59 AM
isaacson06
Guest
Posts: n/a
what i did when i did a auto to manual swap i went to the junk yard and cut the manual tranny mount out of the car and then drilled the spot welds out and put the motor in and tacked it place and then welded it all up and its good to go or you can by the mount from hasport
Old Aug 25, 2007 | 08:45 AM
Johnny Ricer's Avatar
Default Re: (isaacson06)
You need to get the manual trans mounts for your civic just goo to the junk yard and remove them. I believe you need to replace the front bracket, Rear T- Bracket, And the top mount bracket. Somebody correct me if I am wrong.
Old Aug 25, 2007 | 10:02 AM
performancespec's Avatar
Default Re: (soundpsych)
HASport also has the auto to manual mount that will straighten things out.
Id tell you to send me a PM, but they are not active yet
kris
Old Aug 25, 2007 | 10:07 AM
philosofy1's Avatar
Default Re: crooked engine, tranny mount? (blackfoot)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blackfoot &raquo;</TD></TR><TR><TD CLASS="quote">alright , i have a 92 4 door lx, and i did a auto to manual conversion on this car..
do i need a special mount from the transmission to the body so the engine sits striaght??? i heard of these mounts hasport has to offer. but is that neccessairy and am i missing something. </TD></TR></TABLE>
yeah it's all nice eveyone saying to just get the manual bracket and reweld it onto your car, but hasport, innovative, and jdmshit all carry the auto conversion mount. it's a plug n play affair and is 10x easier than cutting, lining, welding a new bracket.
Old Aug 25, 2007 | 11:01 AM
2mansi's Avatar
hasport sells the mount for auto to manual conversion. If you dont want to do that you can drill out the mount (not sure about wording) that is attached to the car re-weld it so that 5 speed mount fits perfect. I did this to my car about a year ago. I did a quick search and found a write up on the whole thing.
Old Aug 28, 2007 | 08:29 AM
Default Re: (2mansi)
Im finally not a Trial member. Contact me and i can set you up with the HASport Auto to Manual swap mount. It doesnt get any easier than this
kris
KPowerSquadron
Aug 16, 2010 04:49 PM
redsikiller
22
May 15, 2006 01:46 PM
4drsleeper123
Jan 28, 2006 05:39 PM
getnasty
Nov 17, 2005 12:56 PM
Si Integra
Mar 9, 2005 12:38 PM
