power window slowing down when going up
Old Aug 25, 2007 | 05:47 AM
Casp3r88's Avatar
Default power window slowing down when going up
I have a 93 civic coupe.... an when ever i go to put up da passenger window is goes up fine until it reaches half way there. The driver side sames to workin just fine it's the passenger that won't work properly.... n'e idea what the problem is?
Modified by Casp3r88 at 10:48 AM 8/25/2007
Old Aug 25, 2007 | 06:35 AM
h2392si's Avatar
Default Re: power window slowing down when going up (Casp3r88)
It might have follen off its guide. Happend to me a while back. You can take the door panel off and see. You'll definately see your problem is when you do this.
Old Aug 25, 2007 | 07:59 AM
cmasonrun's Avatar
Default Re: power window slowing down when going up (h2392si)
the run channels on my civic went bad and got those replaced by the dealer, and its umteen times faster now
Old Aug 25, 2007 | 08:12 AM
3lo's Avatar
3lo
spray some silicone in the chanels or any other lubricant.
Old Aug 25, 2007 | 09:37 AM
zorn's Avatar
could also be the motor going. i have a similar problem with my 94 civic. i've found that if you do one window at time with all powered things off (i.e. radio, lights, wipers) they work a little faster
headrec*
24
Apr 18, 2015 12:08 PM
ricist
Honda Civic (2006 - 2015)
Apr 16, 2008 05:37 PM
fongyz22
Honda Civic (2001 - 2005)
Oct 31, 2007 12:54 PM
poison
Mar 29, 2003 02:47 PM
acuracer
Dec 16, 2001 12:45 PM
