How to check the Y21 tranny fluid level
Old Aug 25, 2007 | 05:23 AM
crazyguy's Avatar
Default How to check the Y21 tranny fluid level
How to check the Y21 tranny (JDM B16A tranny) fluid level?it was leaking a little bit due to loose drain screw.i have tightened it but i am not sure how much it was being leaking and also how much amount of tranny fluid do i need to refill?
appreciate.
Old Aug 25, 2007 | 05:25 AM
pat92si's Avatar
Default Re: How to check the Y21 tranny fluid level (crazyguy)
just take the fill plug out, put a small funnel with a tube in there and fill it until it starts to have the excess coming out.
Old Aug 25, 2007 | 09:06 AM
crazyguy's Avatar
Default Re: How to check the Y21 tranny fluid level (pat92si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pat92si &raquo;</TD></TR><TR><TD CLASS="quote">just take the fill plug out, put a small funnel with a tube in there and fill it until it starts to have the excess coming out.</TD></TR></TABLE>
yes sir.i refilled the tranny flulid until it over flow from the refill plug.thanks for the advise.i guess i would have to do it the correct way.there is no short cut
Old Aug 25, 2007 | 09:46 AM
philosofy1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crazyguy &raquo;</TD></TR><TR><TD CLASS="quote">
yes sir.i refilled the tranny flulid until it over flow from the refill plug.thanks for the advise.i guess i would have to do it the correct way.there is no short cut</TD></TR></TABLE>
that is the correct way, there is no short cuts. you can't check the fluid level on a manual tranny.
especially when changing the fluid, you remove the drain plug, dump the fluid, replace plug, remove fill plug, and add until fluid comes out, this is how it's done.
JDMfrontedLS
17
Jun 23, 2006 11:08 AM
vtec25
Mar 15, 2006 12:54 PM
litterbox
Feb 14, 2005 12:19 PM
luciffer
Sep 13, 2004 11:24 AM
01-1293
Jul 9, 2002 08:34 PM
