What's RPM to launch at?
Old Aug 24, 2007 | 09:27 PM
sherdog9's Avatar
Default What's RPM to launch at?
GSR engine so what's the best RPM to launch on this engine on street tire?
thanks
Old Aug 24, 2007 | 10:01 PM
nsxmatt's Avatar
Default Re: What's RPM to launch at? (sherdog9)
There is no set rpm. Go out and practice and find out for yourself.
Old Aug 24, 2007 | 10:18 PM
EG civic's Avatar
Default Re: What's RPM to launch at? (nsxmatt)
I think the picture under your screen name matches you very well.
Old Aug 25, 2007 | 05:24 AM
sherdog9's Avatar
Default Re: What's RPM to launch at? (EG civic)
^^^looks like your father doesn't it ?
Old Aug 25, 2007 | 10:53 AM
Rickdrizzle's Avatar
different conditions, different launches.
is this in an integra body? or a hatch? tires? road conditions?
**** like that matters.
Old Aug 25, 2007 | 11:12 AM
D-Rob's Avatar
Default Re: (Rick to the y)
8,000+ RPM.
- Derek
Old Aug 25, 2007 | 01:04 PM
sherdog9's Avatar
it's on del sol. 2400lb car only. brand new tires + light rims
Old Aug 25, 2007 | 01:34 PM
Chiovnidca's Avatar
Default Re: (sherdog9)
8500
Old Aug 25, 2007 | 01:41 PM
nsxmatt's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sherdog9 &raquo;</TD></TR><TR><TD CLASS="quote">it's on del sol. 2400lb car only. brand new tires + light rims</TD></TR></TABLE>
Nobody cares! Read the replies you have got so far. The exact same car at the exact same track will launch at a different RPM nearly every trip to the track. The driver is what has to tell the car what RPM to launch at and you won't find that posting on Honda-Tech.
Like was said before, and hundereds of times before that.. go to the track and learn to drive it!
Old Aug 27, 2007 | 01:15 PM
RaceProfessor's Avatar
On regular street tires try 3,800.
Old Aug 27, 2007 | 01:55 PM
street dream gsr's Avatar
* B A N N E D *
Default Re: What's RPM to launch at? (RaceProfessor)
9800rpms.
YOU NEED TO GIVE SPECS.
Old Aug 28, 2007 | 12:39 PM
girliehonda's Avatar
Default Re: What's RPM to launch at? (street dream gsr)
My friend like it at 4000 RPM.
Old Aug 29, 2007 | 09:21 PM
KevinT707's Avatar
I've used various street (non DR) tires at a couple tracks here in GA and I've always had my launch control set at 4K. I've noticed that 4K on street tires was only good when they prepped the track really good. Besides that though on normal conditions I'd rather it be lower, perhaps 3-3500 or something. This is on a LS/VTEC CRX (175 WHP) BTW.
Old Aug 30, 2007 | 12:06 AM
90dxhmt's Avatar
Default Re: (KevinT707)
fuel cut
Old Aug 30, 2007 | 05:59 AM
Rage Cayman's Avatar
Try to get a chipped P28 with the rev limit remove ,wire a honda CBR 1000RR tachometer so you can see a clear 10200 RPM, put your tire pressure to 42psi or a little higher,then dump the clutch and you will be all set
Old Aug 30, 2007 | 06:51 AM
* B A N N E D *
Default Re: (Rage Cayman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rage Cayman &raquo;</TD></TR><TR><TD CLASS="quote">Try to get a chipped P28 with the rev limit remove ,wire a honda CBR 1000RR tachometer so you can see a clear 10200 RPM, put your tire pressure to 42psi or a little higher,then dump the clutch and you will be all set</TD></TR></TABLE>
splashy
Mar 23, 2012 07:36 PM
ennohohbee
May 9, 2010 05:12 AM
jdmeg6118
Apr 17, 2010 09:37 PM
xDelSolSiR
16
Mar 3, 2008 08:36 PM
SICKSOLSI
Jun 29, 2004 08:43 PM
