Broken Motor Mount.. A lesson learned
Old Aug 24, 2007 | 06:05 PM
sirhavok's Avatar
Default Broken Motor Mount.. A lesson learned
Ok so i knew my front motor mount was a little broken, and was just waiting it out till i get it fixed..
NOT A GOOD THING TO DO!!!
Since there was so much movement on the tranny
it snapped the bolt off that holds on the shiftlinkage to the tranny
so im currently working on getting that tapped out.
the passanger side axLe boot ripped..
It was going to be an easy fix.
but since the bolts on my exhaust manifold are stripped. i have to cut the whole thing off, lucky i have an extra exhaust manifold and little down pipe.
the reason i have to cut that to pieces cuz it wont come off, and i cant tap the bolt cuz i cant get the drill straight and dont wanna jack p the threading...
BLAH@!!
dont drive on a messed up MM
Old Aug 24, 2007 | 06:41 PM
Tippyman's Avatar
Default Re: Broken Motor Mount.. A lesson learned (sirhavok)
I didn't have a front motor mount for about 6 months, and m any people can't even run them due to clearance issues. You shouldn't be breaking that much **** just because of the front tranny mount...
Old Aug 24, 2007 | 07:14 PM
IDB4TW!!!'s Avatar
Default Re: Broken Motor Mount.. A lesson learned (Tippyman)
i dont have a front mount just the tranny, behind motor, and drivers side how can i make one for the front i to have a clearence problem.
Old Aug 24, 2007 | 09:42 PM
placid888's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tippyman &raquo;</TD></TR><TR><TD CLASS="quote">I didn't have a front motor mount for about 6 months, and m any people can't even run them due to clearance issues. You shouldn't be breaking that much **** just because of the front tranny mount...</TD></TR></TABLE>
not only the front mount, the rear mount could worn out too
Old Aug 24, 2007 | 09:58 PM
sanimalp's Avatar
$cat /dev/urandom
Default Re: Broken Motor Mount.. A lesson learned (placid888)
i dont think i would run no front motor mount without aftermarket mounts, or filled stock ones.. the factory motor mounts are not made so much for strength as they are vibration damping.
Old Aug 24, 2007 | 10:19 PM
IP RACING's Avatar
Default Re: Broken Motor Mount.. A lesson learned (sanimalp)
Ive been running on a ripped motor mount for about 4 months I keep forgetting about it and when I do have days off plans are already made so I havent gotten around to it
Old Aug 24, 2007 | 10:58 PM
Hamstr323's Avatar
THERE HAD TO BE MORE TO IT THEN JUST THE FRONT MOUNT
my front mount was torn apart and I drove the car daily for almost a year with no problems before I changed the tranny and put another one on
Old Aug 25, 2007 | 09:49 AM
sirhavok's Avatar
All my mounts are good except the front one. and i get tons of movement. like the damn motor wants to jump out the engine bay.
its only a b16a, i know the "torquesless wonder"
but i get a lot of movement on the motor due to the front MM all messed up.
i went through and checked all my mounts when i swapped in the tranny, so i know the rest of them are all in good shape.
Old Aug 25, 2007 | 11:01 AM
Hamstr323's Avatar
Default Re: (sirhavok)
o.k what car is this?? with what mounts stock? or aftermarket?
Old Aug 25, 2007 | 11:15 AM
sirhavok's Avatar
its a 89' civic si
with jdm b16a and jdm s1 tranny
this was an old school swap and i guess they
used LS mounts and brackets
i guess thats the way they use to do it back before people made kits for them.
thats what eugine from Prostreetimports told me.
Old Aug 25, 2007 | 11:35 AM
Hamstr323's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sirhavok &raquo;</TD></TR><TR><TD CLASS="quote">its a 89' civic si
YEP THAT IS OLD SCHOOL
also maybe you should try these
http://www.innovativemounts.co...19350
Old Aug 25, 2007 | 01:35 PM
IDB4TW!!!'s Avatar
Default Re: (Hamstr323)
i have a b16a in my 90 crx but that front mount dosent line up with the front mount position how do i set it up so i can use it because i to get some movement.
Old Aug 25, 2007 | 02:13 PM
sirhavok's Avatar
Default Re: (hondacrxb16)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondacrxb16 &raquo;</TD></TR><TR><TD CLASS="quote">i have a b16a in my 90 crx but that front mount dosent line up with the front mount position how do i set it up so i can use it because i to get some movement.</TD></TR></TABLE>
i have no idea..
i know they have kits for them now.
but as for me, they welded in custom brackets for the mounts.. so it kinda screws me with using any after market MM.
i have a place racing front motor mount and it dont fit..
sucks..
Old Aug 25, 2007 | 02:15 PM
Hamstr323's Avatar
then just use poly inserts for the teg and forget about the front mount
Old Aug 25, 2007 | 02:24 PM
sirhavok's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hamstr323 &raquo;</TD></TR><TR><TD CLASS="quote">then just use poly inserts for the teg and forget about the front mount</TD></TR></TABLE>
thats what im waiting for right now.
did the home made poly kit thing.. meh
seems pretty stiff to me! looks like it will work ok
Old Aug 25, 2007 | 02:26 PM
Hamstr323's Avatar
did that before and worked like a charm
Old Aug 25, 2007 | 09:24 PM
Tippyman's Avatar
Windo- weld FTW.
Old Aug 26, 2007 | 12:00 AM
sirhavok's Avatar
so the mount is drying nicely..
and i used a bolt extractor to take out the broken bolt from the tranny.
and i rebuilt my axle.. all looks good to go as soon as the MM completely drys..
wish my poor little car luck.
Old Aug 26, 2007 | 12:19 AM
Hamstr323's Avatar
make sure you let it cure trust me
are you just doing that one or all?
Old Aug 27, 2007 | 10:04 PM
sanimalp's Avatar
$cat /dev/urandom
Default Re: (Tippyman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tippyman &raquo;</TD></TR><TR><TD CLASS="quote">Windo- weld FTW.</TD></TR></TABLE>
x2
TEGRA98GSR
Apr 21, 2010 09:47 PM
RNPoo7
Mar 28, 2007 01:16 PM
..::91TEG-G2::..
Apr 26, 2006 06:32 AM
gsrstyle
Dec 23, 2002 02:27 AM
