Condition of timing belt
Old Aug 24, 2007 | 05:14 PM
freezerman's Avatar
Default Condition of timing belt
I just purchased a 97 accord with 126k on it. I bought it from a small time dealer in town. I figured the belt should have been done by now so I asked the dealer about it. He said when he replaced the valve cover gasket he inspected the belt and it looked brand new. My question is can you tell the condition of the belt by taking off the valve cover? Is this guy pulling my leg? When I got the car home I changed the oil and flushed the trany fluid. While under the car I noticed some drips of oil on the bottom of timing belt cover. I'm hoping it's just residual oil from the valve cover leak and not the cam or balancer seal. A leak inside the cover will contaminate the belt won't it? I have a 60 day warranty so should I take him up on it?
Old Aug 25, 2007 | 10:58 AM
JimBlake's Avatar
Default Re: Condition of timing belt (freezerman)
I've never had much faith in being able to inspect a timing belt & know it'll last another 20k miles or only 200 miles.
But for the oil leak, keep an eye on it & take him up on his warranty before it expires.
Old Aug 25, 2007 | 05:17 PM
hondamark35's Avatar
you can tell if a belt is old or new by taking the VC off. how old, how new.. not really. unless the oil is just gushing out i wouldn't worry about it getting on the belt. however, this is a sign that the belt hasn't been done, or that it wasn't done correctly.
if the belt was done i the last 20k like it should have been then it shouldn't be leaking any oil from those very new seals which should be replaced when the belt is. you can also look at the back of the block from the top drivers side and you should see a strip of fresh looking aluminum between the Tbelt cover and the block. that's a new waterpump. that should be replaced with the belt as well.
curvenut
Jul 24, 2013 06:12 PM
ottoman213@hotmail.com
May 25, 2011 06:10 PM
kikwear002
Dec 5, 2004 07:35 PM
Brewer
20
Sep 17, 2004 11:34 PM
PearlWhiteAccord
Aug 13, 2002 12:41 PM
