Anyone converted from 3-wire to 2-wire IACV?
Old Aug 24, 2007 | 03:01 PM
asdfbrendan's Avatar
Default Anyone converted from 3-wire to 2-wire IACV?
I just converted my automatic transmission to a manual. My new ECU is expecting a 2-wire IACV and my current IACV is 3-wire, so I'm replacing my throttle body & IACV. Has anyone else done this? If so I'd like to ask some questions...Thanks!
Old Aug 24, 2007 | 03:05 PM
97Ej6mike's Avatar
Yes it can be done, but when i did my swap i did myself the favor of getting a new harness as well so i could avoid this confusion. Have you tried the search option? theres a write-up on this somewhere.
Old Aug 24, 2007 | 03:10 PM
Yeah, I saw the article about it in Auto to Manual conversion FAQ. I know it can be done, I just wanted to make sure I was switching to the right throttle body. I'm gonna put in a 97 EX throttle body in my 98 HX. Any reason that would cause a problem?
Old Aug 24, 2007 | 03:13 PM
97Ej6mike's Avatar
Default Re: (asdfbrendan)
well, that may not be entirly correct. Does the manifold your using support the IACV in its rear, the 2-wire? On autos the IACV is 3 wire and located on the TB alone (d16y7's) , where as in other cases with 2-wire, the IACV has use within the back of the manifold, and passages thru the TB, to just outside the throttle butterfly.
COuld you list your setup of parts?
Old Aug 24, 2007 | 04:28 PM
ekb16's Avatar
Default Re: Anyone converted from 3-wire to 2-wire IACV? (asdfbrendan)
DarkDaysX6
Jul 9, 2013 05:53 PM
javifunksEK
10
Feb 28, 2011 08:10 PM
calvin924597
Jan 29, 2010 06:24 AM
perseverance
Nov 27, 2006 03:57 PM
