Safe Rev limit
With my current setup I am running a B16 with a stock block, Wiesco Pistons, Eagle Rods and a Supertech head. The car is redlining at 9200 rpms. Is this pretty safe with a stock block or should I not run it that high? I bought the car with this setup and have been out of the scene for a while and am just trying to get some thoughts on the issue. Thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nWilk666 »</TD></TR><TR><TD CLASS="quote">if the head is built for it, rip on that bittt
agreed...Valve float or failure is what will kill it before the bottom end ever comes apart. I ran my stock B16 past 9k daily. Granted..I didn't care if it blew, but it stayed together. Finally...one day, it cracked a valve retainer and dropped a valve in under easy driving.
It usually always comes down to those valves and retainers.
</TD></TR></TABLE>agreed...Valve float or failure is what will kill it before the bottom end ever comes apart. I ran my stock B16 past 9k daily. Granted..I didn't care if it blew, but it stayed together. Finally...one day, it cracked a valve retainer and dropped a valve in under easy driving.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ha...tch »</TD></TR><TR><TD CLASS="quote">if you have all that work u can run that b16 to 11k rpms all day long</TD></TR></TABLE>
you need more than dvs's to run up to 11,000, but 9200 is fine
trying to figure out the same thing for my own setup (dont mean to thread jack)..
..but i got a stock ctr motor with boost and am currently only taking it to 8250..
how safe will it to be to take it to 9000?
considering its already making 291whp @ 8250 im wondering if taking it to 9k will cause the bottom or top to fail first.. ?
HELP!
HELP!
